26 registered members (Apache1, 3B, Bill Marlow, 68ironhead, 5 Window 9434, bluesman, 2 invisible),
234
guests, and 3
spiders. |
Key:
Admin,
Mod
Forums47
Topics113,320
Posts898,690
Members41,594
Most Online940 Apr 5th, 2017
12 Volt Conversion
#1289170
Thu Nov 29 2018 03:13 AM
I have read several articles about 12 volt conversion. I will need to do this to add a 7 way plug to utilize my trailer's electric brakes. Those of you that have converted, did you buy a conversion "kit" or did you do better buying the individual items and make your own "kit".
Re: 12 Volt Conversion
[Re: kclark2227]
#1289171
Thu Nov 29 2018 03:17 AM
What year? Up to 50’s can be as simple as new light bulbs, an alternator, and resistor each for coil and fuel gauge. Later might be more complicated but I doubt by much, I’m just not familiar with the newer trucks.
[Re: kclark2227]
#1289227
Thu Nov 29 2018 03:51 PM
Lenexa Ks.
You pretty well nailed it Grigg. Anything mid 50's on up is all ready 12 volts. He will probably use a 12 volt radio. Put a resister on the heater circuit or a 12 volt blower motor. I have run 6 volt heaters on 12 volts.
[Re: kclark2227]
#1290133
Fri Dec 07 2018 12:08 AM
I converted my 51 to 12 volts. I used a 12 volt generator and regulator, resistors for the heater motor and another type for the the gas gauge. I used a 12 volt coil that does not require a resistor, as marked on the side of it. The heater resistor is 1 ohm 50 watts and the gas gauge resistor is 30 ohms 2 watt.
I used a reflector type headlight that uses an H4 bulb. They are very bright with a modern type pattern. They look almost identical to a sealed beam unit.
