The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 registered members (coilover, 66flea, MikeE, John L., ArtA, Green_98), 75 guests, and 3 spiders.
Forums47
Topics114,637
Posts909,513
Members41,974
Most Online940
Apr 5th, 2017
Image Posting Policy
SBC/BBC bell housing question #1290001
Wed Dec 05 2018 10:29 PM
jerryrigged  Offline OP
Arkansas
I'm wanting to put a 250 inline six & T5 in my '46 1/2T pickup. I've read some threads about modifying input shafts and/or adapter plates, and have tentatively formed a plan. I've found a 12.75 OD 153 t flywheel from a 250 six Camaro, and a generic aluminum bell housing to mock up shaft lengths etc. This bell housing is 6 & 5/16 inches deep (from surface that bolts to the block to surface where trans mounts). I think I want a bell housing from a 4.3L V6 Camaro or similar that has an integral mount for a slave cylinder cast in. My question is are all the later type bell housings (not truck) for SBC/BBC/V6 (4.3L)/inline 230/250 sixes the same depth? And are all the holes for the input shaft bearing support 4.675" ?
Thanks in advance for any info/opinions...
-Jerryrigged
Re: SBC/BBC bell housing question [Re: jerryrigged] #1290112
Thu Dec 06 2018 08:37 PM
EdPruss  Offline
Longmont, CO
Your modern 250 six is about 3" longer than your original engine, you will have to allow for that.
Ed
Re: SBC/BBC bell housing question [Re: jerryrigged] #1290131
Thu Dec 06 2018 11:19 PM
Arkansas
Thanks, I'm aware of that. I know I'll need to relieve the firewall for clearance as everything is located by the radiator support; & I'll have to fabricate motor mounts, etc. I'm just trying to figure out now if the bell housing I have will work for length dimensions to mock up the driveline. I plan to keep the floor pedals if possible, and thought a hydraulic clutch activation would be easiest.
-Jerry
Moderated by  SWEET
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
