The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Tech Tip Highlight
Get your truck ready for winter
This old Tech Tip stands the test of time
Check for details
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
16 registered members (bartender, moparguy, Green_98, HandyAndy, D B Cooper, 1 invisible), 174 guests, and 3 spiders.
Forums47
Topics113,535
Posts894,153
Members41,351
Most Online940
Apr 5th, 2017
Image Posting Policy
1954 Chevrolet Hydra-Matic parts truck #1289271
Thu Nov 29 2018 09:11 PM
jorb  Offline OP
Wis
1954 Chevy 5 Window 3100 1/2 ton plus parts truck Hydramatic 4 speed hot rat rod eBay
Also has windshield and front doors stainless steel moulding..
That might be a HM starter on the floor in that one photo.
1954 Chevrolet 3105 Deluxe Panel Truck
w/Factory HYDRA-MATIC
Re: 1954 Chevrolet Hydra-Matic parts truck [Re: jorb] #1289284
Thu Nov 29 2018 10:27 PM
tclederman  Online
Boltergeist
Jarvisburg, NC
If both rear ends are 1954, both the Hydra-Matic and manual rear ends were 3.90; but, I think they have different length torque-tubes (I'll check if anyone wants to be certain).
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 47 years
1954 3104 5-window pickup w/Hydra-Matic
Z-series (54/55) GMC 350 (2-ton) COE
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: 1954 Chevrolet Hydra-Matic parts truck [Re: jorb] #1289310
Fri Nov 30 2018 01:06 AM
Greg_H  Offline
Enid Okla
correct...different driveshaft lengths.
Re: 1954 Chevrolet Hydra-Matic parts truck [Re: Greg_H] #1289880
Tue Dec 04 2018 09:07 PM
jorb  Offline OP
Wis
Yep, HM 1/2 ton torque tube and propeller shaft is a little shorter than the manual trans. torque tube and propeller shaft.
The 1/2 ton torque tube and propeller shaft was shortened for one year, just for the Chevrolet 1954 truck w/HM.
Check attached
hm driveline rz.jpg (117 downloads)
Re: 1954 Chevrolet Hydra-Matic parts truck [Re: jorb] #1289882
Tue Dec 04 2018 09:38 PM
tclederman  Online
Boltergeist
Jarvisburg, NC
Aah, a picture is always worth much more than words.
Tim
Re: 1954 Chevrolet Hydra-Matic parts truck [Re: tclederman] #1290118
Thu Dec 06 2018 09:27 PM
jorb  Offline OP
Wis
Sold,
Not a bad deal for $5100.00 smackaroos,
Two 54 trucks, One of them being a HM truck and both have clear titles.
https://www.ebay.com/itm/1954-Chevr...rt=nc&_trksid=p2047675.m43663.l44720
If you restore the HM truck you have to use the HM cab because it has the arch in the toe board and the gas pedal on the tranny service cover.
Plus the HM frame has the riveted on ears for the removable cross member.
They also did not punch a hole in the toe board for the clutch pedal.
No one repops the HM firewall.
The firewall and toe board are one stamped out piece of metal.
1st pic manual tranny cab
2nd pic HM tranny cab arched toe board.
manual cab 3.jpg (24 downloads)
hm cab 8.jpg (24 downloads)
Moderated by  John Milliman, Tiny
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
