The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
A lovely month ...
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
24 registered members (3B, cmayna, Bill Marlow, 68ironhead, 5 Window 9434, bluesman, 2 invisible), 232 guests, and 3 spiders.
Forums47
Topics113,320
Posts898,690
Members41,594
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 3 1 2 3
Re: Clutch head screw removal [Re: snotnose] #1290080
Thu Dec 06 2018 03:31 PM
cmayna  Online
Menlo Park, Ca
Similar to what snotnose (what a name!) has done, I've used my dremel with cut off blades and would grind a flat spot on one side of the head, then over on the other side, giving two parallel flat spots for a pair of small vice grips. Before tweaking, I'd of course use some Pentron or homemade batch of ATF/Acetone, to help break it loose.
Craig's '50 Chevy 3100 5 window
My truck
If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
Re: Clutch head screw removal [Re: snotnose] #1290088
Thu Dec 06 2018 04:58 PM
Brad Allen  Offline
Salt Lake City, Utah
Dremel tool huh?
Re: Clutch head screw removal [Re: snotnose] #1290099
Thu Dec 06 2018 07:34 PM
Hotrod Lincoln  Online
Boltergeist
Dellrose, TN
I use a 1/16" wide cutoff disc on a 3" angle grinder to cut a slot for a straight-blade screwdriver. One quick pass and it's done.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Clutch head screw removal [Re: snotnose] #1290103
Thu Dec 06 2018 08:01 PM
bartamos  Offline
State48 Ranch
Big boys use angle grinders.
1960 GMC K1001 (The Oreo SpeedWagon)
To each his own or the Highway.
All I know is what the voices in my head tell me and a little from watching TV.
Re: Clutch head screw removal [Re: snotnose] #1290109
Thu Dec 06 2018 08:29 PM
Brad Allen  Offline
Rarified air.
Re: Clutch head screw removal [Re: snotnose] #1290117
Thu Dec 06 2018 09:24 PM
bartamos  Offline
State48 Ranch
Yes, air or electric. nanner
Re: Clutch head screw removal [Re: snotnose] #1290145
Fri Dec 07 2018 01:42 AM
cmayna  Online
Menlo Park, Ca
I have a couple angle grinders both air and electric, but for the size of the typical clutch screw head, little Mr. Dremel works like a champ................at least for me.
My truck
Re: Clutch head screw removal [Re: snotnose] #1290146
Fri Dec 07 2018 01:57 AM
bartamos  Offline
State48 Ranch
Tried my Dremel several times. Not robust enough for me. .093 and .125 dia shafts. Will try it again sometime. Stuck on die grinders and angle grinders for now.
BTW: Brad has an awesome collection on his Flickr pages.
Re: Clutch head screw removal [Re: snotnose] #1290147
Fri Dec 07 2018 01:58 AM
52Carl  Offline
Virginia
Hey Jerry, you still got the guard on that angle grinder? Hmmm? smile
Carl
Safety first.
Unless it gets in the way of course.
Re: Clutch head screw removal [Re: snotnose] #1290148
Fri Dec 07 2018 02:00 AM
Achipmunk  Offline
Boiling Springs, S. C. 29316
I have worked on many clutch head screws myself. Like most of you, my arsenal includes, using a flat screw driver, drilling, penetrating oil, dremel, grinder, impact screwdriver and a couple homemade ones.....the one thing I didn't mention but is probably the most important of all is PATIENCE.
..... I'll admit to using one of my dremels on more than one occasion. Handy to have working on metal or my woodworking .........
i even like the way the dang little things "sings" when i turn it on.
Pictures in my Photobucket
52 Chevy Panel
Page 2 of 3 1 2 3
Moderated by  Justhorsenround
Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
