The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 registered members (darthintel, 51sub, 52Carl, Elmo, 1946GMCDAN, Konajoe, 1 invisible), 84 guests, and 2 spiders.
Forums47
Topics114,638
Posts909,515
Members41,974
Most Online940
Apr 5th, 2017
Image Posting Policy
Door sound deadening material removal #1290055
Thu Dec 06 2018 05:23 AM
Fox  Offline OP
Breton, Alberta
1970 c10 1/2 ton.
I’m working on my doors and have been scraping off the factory “sound deadening” material that looks like junk bed liner from the inside. It started, at first, coming off in chunks with my scraper but now I’ve reached the stuff that still sticks and I can’t scrape it off.
What is your best way to remove this junk?
Heat and scrape? Time consuming...I have lots of time.😃
Wire wheel? Hard to reach in? I hate contorting...😡
Chemical peel?🤪
Whatcha think?
More pictures here
1953 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- rusted
1970 Chevrolet K20 Suburban—rusted.
1950 Chevrolet 1300- in progress to shiny.
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
Re: Door sound deadening material removal [Re: Fox] #1290059
Thu Dec 06 2018 09:40 AM
miraclepieco  Offline
OR
I'm familiar with earlier models - is this that nasty tar-like stuff? I pre-soaked the inside of the door for a couple of days with WD40, then used a heat gun and putty knife. It released pretty quick once the WD40 penetrated under it. Stubborn spots required additional applications. Obviously don't get the metal so hot that you warp it. Clean up the oily residue with lacquer thinner.
1951 Chevy Panel Truck
Re: Door sound deadening material removal [Re: Fox] #1290153
Fri Dec 07 2018 02:08 AM
Achipmunk  Offline
Boiling Springs, S. C. 29316
Junk? Its been on there quite a few years. If its "hidden" why not leave it and put what ever you use over it to...
Oh, I know, "do it once and do it right".....right?
Pictures in my Photobucket
52 Chevy Panel
Re: Door sound deadening material removal [Re: Fox] #1290163
Fri Dec 07 2018 02:32 AM
52Carl  Online
Virginia
If you cannot scrape it off, you likely will not have rust issues under it. Get off what you can and foe ged about it.
Re: Door sound deadening material removal [Re: Fox] #1290167
Fri Dec 07 2018 04:04 AM
Fox  Offline OP
Breton, Alberta
I’ve thought about leaving it, but as Alvin said....OCD much? I agree with you all about how it has lasted 48 years, it should be ok, but if “I’ve come this far may as well go all the way...”
Perhaps I’ll see the light once I’ve fought for too long trying to remove it. 😉 Thanks fellas.
More pictures here
Parts trucks-
1951 GMC 9300
1951-GMC 9430
Moderated by  48bigtrucks
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
