The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 members (Ted Skidmore, Fox, bigmacdaddy, 1 invisible), 180 guests, and 3 robots.
Forums50
Topics121,365
Posts977,661
Members44,213
Most Online1,229
Jan 21st, 2020
Image Posting Policy
low rider or??????????
#128974 Mon Jul 08 2002 02:16 PM
6T2Burb Offline OP
I currently have a 63 chevy short bed stepside. The question I have is do I lower it, or 4x4 it? The truck has many problems that money and time will fix. Since I have a 77 K-5 4x4 frame, and a 89 Caprice, I can go either way. grin I have checked the dimensions and the 89 Caprice frame will work. I will have heavy duty discs up front and a rear sway bar. Plus the motor and transmission. smile
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe
1947 Chev Coupe
1969 GTO ragtop
Re: low rider or??????????
#128975 Mon Jul 08 2002 05:59 PM
Low...slow... with alot of go is my vote.Airbag the suspension and throw some '20's on it!I've swapped bodies before from 2wheel frame to 4wheel using a 3ton engine hoist and blocks to seperate/transplant to a 4wheel frame.I did it in one weekend with hand tools-solo.But that was with a '73 fulltop blazer.I've also converted my brothers 4 wheel '72 blazer from 4 to 2 wheel by swapping front crossmembers,rearends and drive-trains.Take good measurements prior to ripping everything apart,take pictures with a disposeable camera for reference purposes,and go at it.Anythings possible with a sawsall,a torch and a little time- enjoy yourself.
#128976 Tue Jul 09 2002 02:06 PM
6T2Burb Offline OP
Thanks for the info! I'll stick with my original pan to go lo,' as you say. grin grin
1947 Chev Coupe
1969 GTO ragtop
Moderated by  KCMongo
