ODSS Bolters return from
WINCHESTER
Virginia
September 21-23
Read the
HOT WASH!
Forums65
Topics123,412
Posts999,067
Members47,256
Most Online1,229 Jan 21st, 2020
#128951
Sat Dec 22 2001 04:18 PM
OP
How closley matched are the cabs for the trucks from 1939-40 till 47? I am trying to install a newer style brake cylinder on the firewall and have a set of instructions for a 47 1/2 ton but would like to know if the "ribs" and seams are even closely matched? Any idea's out there?
#128952
Tue Dec 25 2001 10:13 PM
Believe confusion begins with the mid-year design change in '47. Quite a different truck than the Wurlitzers...
#128953
Wed Dec 26 2001 02:02 AM
When I mounted the power booster on my 46 I made a doubler. Then I had to put a piece of angle alum on each side of the swing pedal bracket and then a piece of flat stock back to the dash from the top of the bracket to keep the firewall from flexing.
#128954
Wed Dec 26 2001 07:23 PM
besides a bracket to the dash, a large piece of 1/4" plate on the inside of the firewall will stiffen it considerably.
