The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (D B Cooper, elhippie64, David Waddell, 3B, Flatblu4748, Bill Trotter), 306 guests, and 3 robots.
Forums50
Topics121,474
Posts973,858
Members43,939
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Coil wiring 1950 3100
#1287576 Thu Nov 15 2018 10:00 PM
Jhyp Offline OP
A little help please. Does the ignition switch wire connect to the positive or negative side of the coil? Tkx
Re: Coil wiring 1950 3100
Jhyp #1287587 Thu Nov 15 2018 11:15 PM
+ to the switch. - to the points. The coil will work wired backwards, but, not as well. The windings in the coil are insulated from the can outside. So it will not short out. The coil is wound in a manner that reversing the current flow may reduce the output voltage(efficency) . That is an "Engineer" convesation that we can avoid. The last conversation I got stuck in like that was about "hole flow". Look it up if you need to. Still makes my headake after 50 years.
Steve H
Jhyp #1288032 Mon Nov 19 2018 03:41 AM
That’s interesting Steve. I never knew it made a difference which side the ignition was wired to. I learned something today!
Chuck
1950 Chevy 1/2 ton (original)
1941 Chevy coupe
1938 Chevy coupe streetrod
Jhyp #1288033 Mon Nov 19 2018 03:54 AM
Boltergeist
Just to muddy the waters a little more- - - - -the real culprit to reversed coil polarity is "inductive reactance"- - - -the resistance to current flow in the primary coil winding if the end of the secondary coil winding is at the distributor side instead of the ignition switch side.
LOL!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Jhyp #1288342 Wed Nov 21 2018 11:04 PM
I've never thought about too much coil polarity. Just hooked it up the way it was supposed to be. I got curious and wondered why? Stumbled on this, and now it makes sense. Tesla would have known that for sure too.
http://mgaguru.com/mgtech/ignition/ig104.htm
Jhyp #1288388 Thu Nov 22 2018 05:35 AM
Shop Clutterist
Thanks 4100. Inquiring minds like to know! thumbs_up
Gord
1954 1/2 ton 235 4 speed
Moderated by  Rusty Rod
