The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (Hambone, 51 2 Ton, glenns towing, boonie, 3 invisible), 214 guests, and 3 robots.
Forums50
Topics120,637
Posts967,011
Members43,723
Most Online1,229
Jan 21st, 2020
Image Posting Policy
57 and 59 chassis differences
#1287247 Tue Nov 13 2018 03:43 AM
J Lucas Offline OP
Workshop Owner
To the best of my knowledge, 1957 to 59 half ton Chevy frame, axles, linkage, shock mounts, steering box etc are the same. Both have short boxes although the 57 is a stepside and the 59 is fleetside. Everything mechanical underneath should interchange. Does that sound correct?
J Lucas
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
1959 Chevy Apache 31 Fleetside
1959 Chevy Apache 32 Fleetside
1959 Chevy Viking 40
My Flicker Photos! [flickr.com]
Re: 57 and 59 chassis differences
J Lucas #1287253 Tue Nov 13 2018 04:28 AM
Yes and no...the mechanical stuff is the same, but the frames are different between the 55-57 and 58/59. The 58/59 frames are longer at the front bumper.
Mike B smile
J Lucas #1287255 Tue Nov 13 2018 04:51 AM
J Lucas Offline OP
Workshop Owner
J Lucas
1941 Chevy 1/2-Ton
J Lucas #1287257 Tue Nov 13 2018 05:48 AM
J Lucas
You will likely find that brake line from master cyl to rear axle assembly differ from 57 to 59. On 57 it crosses over to right side frame & back to rear axle. On 59 it goes back on left side to rear axle. FYI
delky dave in wyo
1957, 3100, v8
1990 Suburban
J Lucas #1287299 Tue Nov 13 2018 04:01 PM
58 and 59's also had a stepside in addition to a fleetside. Rear backing plates are slightly different and use the wider rear brake shoes to match the fronts.
Fred
Moderated by  SWEET
