The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 registered members (Maybellene, 52Carl, Elmo, 1946GMCDAN, 51sub, Konajoe), 86 guests, and 2 spiders.
Forums47
Topics114,638
Posts909,515
Members41,974
Most Online940
Apr 5th, 2017
Image Posting Policy
1949 Bed On A 1946 #1284830
Thu Oct 25 2018 05:25 PM
1946GMCDAN  Online OP
WA
Is there a way to use a bed from a later model short bed on my 46'? I see that the later ones are wider. That would suggest that the fenders would not match up with the running boards. Of course the tail gate would need to be tossed as would the head board. As well as the cross rails. Has anyone done this ? Is it even worth the trouble? Mar K does make a pretty nice kit.
Trombones Totem Poles And Old Trucks!
Re: 1949 Bed On A 1946 [Re: 1946GMCDAN] #1284949
Fri Oct 26 2018 04:01 PM
Lightholder's Dad  Offline
Mesa, AZ
I owned my first antique truck (1942 Chevy half ton) for two months before I realized that the bed was a later '53 version, with the side mount spare tire. I was really new to the hobby and had no idea when I bought it. To mount the bed they had to cut the nice running boards about one inch shorter at the rear. The bed has the 53 fenders; I don't think your original fenders will fit at all.
I bought a Mar K bed for my '37 project as the original was just too beat up and it is very impressive. I would highly recommend you go that route.
Kent
1937 Chevy 1/2 ton (project in progress)
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Re: 1949 Bed On A 1946 [Re: 1946GMCDAN] #1284971
Fri Oct 26 2018 06:15 PM
WA
Thanks. I think you are right about Mar K. I'll probably go that route. But I also wonder about making a half ton short stake bed. I've never seen it done I don't think.
Re: 1949 Bed On A 1946 [Re: 1946GMCDAN] #1285034
Sat Oct 27 2018 02:48 AM
Achipmunk  Offline
Boiling Springs, S. C. 29316
The stake beds are handy.....try it and let us know how it works!
.... I second the Mar-K suggestion and I'll throw in another idea. I have seen later model beds with the flare fenders from rangers or S-10's that were tastefully done and looked good but have not seen one on a 46 Art Deco style.
Pictures in my Photobucket
52 Chevy Panel
Re: 1949 Bed On A 1946 [Re: 1946GMCDAN] #1287139
Mon Nov 12 2018 01:51 PM
V
VEW  Offline
VA
My plan is put an 8' bed on my 41 3/4 ton, from a '66 Jeep. I've measured it several times and know I will need to make several modifications, including adapting the mounting brackets/braces. I'm also putting dual wheels on the rear axle, so I will need extend the rear fenders out to accommodate that, as well as modifying the running boards.
All that is to say, you can do almost anything. "Is it even worth the trouble?" you ask? - - - - I'll let you know when I get it done. smile
Victor
41 3/4 Ton Pick Up (in process)
55 Grumman Kurbside (Doughboy) 235/3 on tree w/ OD
57 3100
58 C4400 Viking (Thor)
59 C4500 Short Bus (Magic Bus)
59 G3800 1 Ton Dually (Chief)
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
