The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Planning for 2019
The Stovebolt Staff drives on to a NEW YEAR
Sincere thanks to all of you who contribute to the site in the various ways.
Keep your eyes on those gauges in
2019
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
6 registered members (Fox, Hotrod Lincoln, Davie, GWWirth, TPR57C, klhansen), 208 guests, and 3 spiders.
Forums47
Topics112,934
Posts894,433
Members41,468
Most Online940
Apr 5th, 2017
Image Posting Policy
3 speed behind new 350SBC #1286762
Fri Nov 09 2018 06:22 PM
Y
Yukon56  Offline OP
Yukon Territory
Hey friends,
I have a 235 currently with a three speed on the floor currently in my 56' 3100. I'm looking to put a 350 SBC in the truck this winter and was wondering if my current bell housing and transmission will bolt up together. I've read around of others having to use a V8 bell housing but I'm not sure if that is the case for me.
Thanks!
Re: 3 speed behind new 350SBC [Re: Yukon56] #1286764
Fri Nov 09 2018 06:43 PM
Jon G  Offline
Dallas, TX
The bellhousing bolt pattern is different for each of those engines.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Re: 3 speed behind new 350SBC [Re: Jon G] #1286766
Fri Nov 09 2018 07:00 PM
Y
Yukon56  Offline OP
Yukon Territory
Thanks Jon,
Would a newer V8 bell housing bolt up to my older 3 speed transmission?
Re: 3 speed behind new 350SBC [Re: Yukon56] #1286775
Fri Nov 09 2018 08:01 PM
3B  Offline
B. C. Canada
Hy Yukon56, you want to find and use a cast iron bellhousing from a 1955B to 1959 Chevrolet V8 truck, this bellhousing will accept your transmission and has the correct rear engine/crossmember mounts cast into it, hope that helps.
Re: 3 speed behind new 350SBC [Re: Yukon56] #1286776
Fri Nov 09 2018 08:30 PM
Jon G  Offline
Dallas, TX
Yes, what 3B just said.
Jon
Re: 3 speed behind new 350SBC [Re: Yukon56] #1286777
Fri Nov 09 2018 08:47 PM
rfs56trk  Offline
Seal Beach, CA
You can also use a bellhousing from a 63 through 66 V-8 or 6 cylinder truck. Same mounting and bolt pattern as 55-59 V-8's.
Fred
Re: 3 speed behind new 350SBC [Re: Yukon56] #1287378
Wed Nov 14 2018 02:16 AM
Y
Yukon56  Offline OP
Yukon Territory
Thank you for the information, its much appreciated.
Matt
Re: 3 speed behind new 350SBC [Re: Yukon56] #1287380
Wed Nov 14 2018 02:25 AM
Hotrod Lincoln  Online
Boltergeist
Dellrose, TN
Some of the early 1960's cast iron bell housings were used with a hydraulic clutch. Those have the throwout fork mounted to the passenger's side of the bellhousing. They fit onto the same mounts as the others, but they're not compatible with mechanical clutch linkage.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: 3 speed behind new 350SBC [Re: Yukon56] #1287436
Wed Nov 14 2018 04:16 PM
rfs56trk  Offline
Seal Beach, CA
The hydraulic cylinder/slave system was used on 60-62 trucks.
Fred
Re: 3 speed behind new 350SBC [Re: Yukon56] #1287517
Thu Nov 15 2018 04:13 AM
EdPruss  Offline
Longmont, CO
The slave cylinders are still available, although made offshore, have PN if one needs it.
Ed
Moderated by  SWEET
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
