The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Think Spring
Start planning those get togethers!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 registered members (ASU, 5 Window 9434), 215 guests, and 3 spiders.
Forums47
Topics113,705
Posts902,286
Members41,678
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 10 of 15 1 2 8 9 10 11 12 14 15
Re: ‘62 C-10 Restomod build begins [Re: Justhorsenround] #1284108
Fri Oct 19 2018 01:03 PM
Justhorsenround  Offline OP
Grease Monkey
Central, Oklahoma
Outside working season is just about done here in Central Oklahoma. We have a warm day every now and then. Unusually rainy Fall this year. So if its warm it has been raining. No cover in the work area. That being said, I have been poking away at the little stuff. PCV system, fuel delivery and vacuum advance. Running hoses,lines and wires. My goal of finishing before my upcoming Hip replacement surgery is fading rapidly. Wiring is kicking my butt. When we took out the 6 my son removed all the under dash wires from the fuse block. He knows where they go, I don't. No power at the fuse block. Tracing wires is not my forte. With 5 kids and a 2 hour daily commute to work ole Dad is on the back burner. Next spring is looking more realistic unless I can find a shop willing to finish the wiring. If so, I'll bite the bullet and trailer the '62 to them. Patience is a virtue I do not possess. eeeek
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: ‘62 C-10 Restomod build begins [Re: Justhorsenround] #1284201
Sat Oct 20 2018 01:05 PM
Grease Monkey
Central, Oklahoma
Long talk with my co-conspirator (son) last night at dinner. It was agreed upon to trailer the ‘62 C-10 to his house where he can do the wiring at his own pace. Still a couple of small things to prep the truck for it’s 2 1/2 mile trip.
Re: ‘62 C-10 Restomod build begins [Re: Justhorsenround] #1284376
Sun Oct 21 2018 08:58 PM
Grease Monkey
Central, Oklahoma
Well after 1 1/2 hours of banging my hand with a hammer cutting the lock out of the winch box (couldn’t find the key) and fiddling with the in/out switch I finally got the ‘62 loaded. Couple of band aids and some neosporen (at least I didn’t need an ambulance) and we were on the road for the short trip to my sons. Once there we off-loaded and gave Terry B a list of electrical stuff he needs to do. Back home in time for the last 88 laps of the Napcar race. 🛠
Re: ‘62 C-10 Restomod build begins [Re: Justhorsenround] #1284432
Mon Oct 22 2018 03:11 AM
klhansen  Offline
Eagle River, Alaska
Is that the race you sleep thru?? grin
Sorry, I couldn't resist. wink
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck.
Re: ‘62 C-10 Restomod build begins [Re: Justhorsenround] #1284463
Mon Oct 22 2018 01:07 PM
Grease Monkey
Central, Oklahoma
Kevin, you know me too well! secret
Re: ‘62 C-10 Restomod build begins [Re: Justhorsenround] #1284467
Mon Oct 22 2018 01:30 PM
tclederman  Offline
Boltergeist
Jarvisburg, NC
"Is that the race you sleep thru?? grin" blush
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 50 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: ‘62 C-10 Restomod build begins [Re: Justhorsenround] #1285116
Sat Oct 27 2018 10:48 PM
Grease Monkey
Central, Oklahoma
Received an update from Terry B (see his ‘53 3100 in the Gallery) just awhile ago. Wiring is 80% complete. The engine cranks, I had given him specific instructions not to try to start it but it was ok to “bump” the starter to test it. He is mounting the torque converter lockup in the dash so he’s got a little dremel tool work to do. The engine harness was redone. Progress!
yahoo
Re: ‘62 C-10 Restomod build begins [Re: Justhorsenround] #1285623
Wed Oct 31 2018 09:35 PM
Grease Monkey
Central, Oklahoma
I have been somewhat dissatisfied with the headers since I put the motor in the truck. The “Shortys” exit right on top of the front crossmember making it necessary to have the header pipe make an immediate 45 degree turn to the rear from the collector. Tight space to work in. Made the decision to put conventional headers on. None of the usual suppliers have headers for SBC listed for 1962 C-10’s. Closest I could get was 1963, so I’m hoping they will fit without much modification.🛠
Re: ‘62 C-10 Restomod build begins [Re: Justhorsenround] #1286761
Fri Nov 09 2018 06:14 PM
Grease Monkey
Central, Oklahoma
Torque converter lockup switch is in. It looks like the factory installed it. Mounted in the dash just to the left of the radio. Next up is wiring the steering column harness so the signals and horn operate. Rewiring the radio and speakers. Cleaning up the underdash wiring and installing new wire loom throughout. We are close but it looks like it’s not going to be finished before my pending surgery. We will get it back over here from Terry B’s and back on the lift before the snow falls. I can keep the battery on a tender that way.🛠
Re: ‘62 C-10 Restomod build begins [Re: Justhorsenround] #1286785
Fri Nov 09 2018 09:56 PM
Achipmunk  Offline
Boiling Springs, S. C. 29316
....Martin, just be glad the doctors don't just do "fifteen minutes a day" or you could be down for a long time. hehe
Good luck. Hope all goes well and your back to your 15 minutes soon!
Pictures in my Photobucket
52 Chevy Panel
Moderated by  Hambone, sixtyfive c-10
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
