The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Planning for 2019
The Stovebolt Staff drives on to a NEW YEAR
Sincere thanks to all of you who contribute to the site in the various ways.
Keep your eyes on those gauges in
2019
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
7 registered members (Fox, Davie, GWWirth, Hotrod Lincoln, klhansen, Jbm), 209 guests, and 3 spiders.
Forums47
Topics112,934
Posts894,433
Members41,468
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 2 1 2
Re: 351 v6 starter solenoid [Re: 61gmc5000] #1286699
Fri Nov 09 2018 05:36 AM
Hotrod Lincoln  Online
Boltergeist
Dellrose, TN
Do it like GM did originally- - - -use a sleeve made of thick wall copper tubing surrounding the screw between the solenoid and the terminal lug on the starter motor.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: 351 v6 starter solenoid [Re: 61gmc5000] #1286700
Fri Nov 09 2018 05:43 AM
61gmc5000  Offline OP
Peru ny
Interesting idea, I started looking for a copper standoff but I could easily make a sleeve like that.
Re: 351 v6 starter solenoid [Re: 61gmc5000] #1286701
Fri Nov 09 2018 05:46 AM
Boltergeist
Dellrose, TN
I've installed hundreds of them over the past 50-something years.
Re: 351 v6 starter solenoid [Re: 61gmc5000] #1286729
Fri Nov 09 2018 03:16 PM
Boltergeist
Dellrose, TN
I buy solid copper round bar in any diameter and length I want on Ebay. I use it to fabricate heat sinks when I'm welding on heat-sensitive components such as rifle bolts when I'm building long range target rifles. With a lathe, a drill press, and some taps and dies, all sorts of possibilities open up.
Re: 351 v6 starter solenoid [Re: 61gmc5000] #1286834
Sat Nov 10 2018 05:25 AM
Peru ny
I found a solution today. Found an old junk torch tip, cut the ends off and drilled it. Results to follow
Page 2 of 2 1 2
Moderated by  53moneypit, Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
