The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
19 registered members (52Carl, C10 - C90 Bill, billinwisconsin, 48bigtrucks, 4 invisible), 304 guests, and 3 spiders.
Forums47
Topics115,010
Posts912,529
Members42,077
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 6 1 2 3 4 5 6
Tired of Ugly Door Panels for AD Trucks #1286025
Sun Nov 04 2018 01:04 PM
sstock  Online OP
Gig Harbor, WA
Last year I finished the cab off restoration of my 53 3100. When I got to the interior, I ordered a nice maroon seat cover from Jim Carter and a new headliner and door panels. I seemed pretty happy with it at the time but now was not happy with how the cardboard door panels wore in just a year. The quality of cardboard is not really good, if you get water on them when you open the door, you will see what I mean. Eventually the cardboard started to pull out of the frames and started to look bad. I ordered 2 pieces of 12" by 36" sheet aluminum that is .050 thick from McMaster Carr and a roll of maroon vinyl from Jim Carter. I then removed the old panel and traced it over the aluminum sheet with a sharpy. Cut out the aluminum with a nice new metal blade for thin metal with a jigsaw and then drilled the appropriate mounting holes on my drill press. Did a quick test fit. Removed and to the workbench to clean the aluminum with some paint surfacer cleaner. I then applied some contact cement to the aluminum and the back side of the vinyl and set aside to dry for 20 minutes. After the contact cement was dry, I carefully laid the vinyl over the aluminum panel and rolled it in with my linoleum roller to press it in and get out any bubbles. This part it is best to have a helper hold the vinyl off the sheet and just touch one corner of the vinyl to the sheet and slowly start rolling the vinyl on as your helper allows more of the vinyl to touch the sheet until it is completely attached. Once attached, you can trim the excess off with a new razor blade and cut out the holes with an exacto knife. Next assembled the metal frame around the door panel and secure the frame on the backside with some duct tape. Then install the panel to the truck, arm rest, window cranks and door handles. It took a couple hours and cost about $80 but looks far better than it did. The key is to get alluminum sheet that is no thicker than .050 so when you add the vinyl it still fits in the metal trim. Hope this helps somebody down the road, cheers.
Steve
1 year old cardboard panels
Finished Passenger Side
Tracing old door panel over .050 Aluminum Sheet 12"by 36"
Cut and drilled out aluminum door panel
Test Fitting
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1286026
Sun Nov 04 2018 01:06 PM
sstock  Online OP
Gig Harbor, WA
More pictures
Attaching vinyl to panel with contact cement
Assembling metal frame around door panel
Finished Driver's Side installed
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1286028
Sun Nov 04 2018 01:10 PM
Brad Allen  Offline
Salt Lake City, Utah
Looks very nice, thanks for the pictures and details.
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1286045
Sun Nov 04 2018 03:49 PM
MNSmith  Offline
So Cal
Looks good!
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1286313
Tue Nov 06 2018 03:48 AM
Achipmunk  Offline
Boiling Springs, S. C. 29316
Pretty Slick......I had thought about doing something like that but you have the "proof in the pudding". Great job and thanks for the details.
Pictures in my Photobucket
52 Chevy Panel
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1286360
Tue Nov 06 2018 02:49 PM
sstock  Online OP
Gig Harbor, WA
Thanks all for your comments.
I can't say enough good about McMaster Carr, they seem to have just about everything for any fabrication, quick shipping and reasonable prices too.
Steve
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1286431
Wed Nov 07 2018 02:35 AM
miraclepieco  Offline
OR
Big improvement over the cardboard.
1951 Chevy Panel Truck
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1286433
Wed Nov 07 2018 03:05 AM
ndkid275  Online
Northern VA
I am curious to see how you tackle the cardboard on the roof!
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1286624
Thu Nov 08 2018 08:53 PM
tom moore  Online
New Hampshire
you can go into production and sell them. looks great.
Re: Tired of Ugly Door Panels for AD Trucks [Re: ndkid275] #1286634
Thu Nov 08 2018 10:38 PM
tclederman  Offline
Boltergeist
Jarvisburg, NC
Ditto
Nice work, Steve
And, nice explanation.
Ditto on ndkid275's post: "I am curious to see how you tackle the cardboard on the roof!"
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 50 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1286638
Thu Nov 08 2018 11:05 PM
DavidBraley  Offline
Fort Collins, Colorado
I like this. Bookmarking now...
-David
1948 2-Ton GMC
Horsepower determines your speed when you hit the wall. Torque determines the size of the hole you make...
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1286892
Sat Nov 10 2018 06:10 PM
66flea  Offline
Williston Park, N.Y..
3/8 inch beadboard with the back routed out
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1286894
Sat Nov 10 2018 06:12 PM
66flea  Offline
i made arm rests to match. i'll post when i find the picture
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287031
Sun Nov 11 2018 06:59 PM
Jon G  Offline
Dallas, TX
Hi Steve.
Nice work. Here's another idea: You can also use Formica counter top material. It is not expensive, comes in a standard thickness of .035", will not warp and it will flex without permanently bending nor developing the wavy bumps fiberboard gets. Cut it so the back side (the rough side) faces outward. If you want to paint it, sand the texture on the back until it is smooth, prime it and spray it after the pieces have been cut. Or coat it with contact cement and cover with vinyl as you've done. The headliner (as you know) has compound/complex curves. You can use a blow drier to help Formica bend to make those curves (the ones at the front) look right. I would not use aluminum on the headliner.
You can also still get upholstery grade fiberboard (here: https://www.perfectfit.com/15347/Chipboard-Car-Panelboard.html ) but the non-waterproof board must be sealed on both sides and at all edges well or it will shrink and warp.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287044
Sun Nov 11 2018 09:14 PM
Justhorsenround  Online
Grease Monkey
El Reno, Okla
Isn’t Formica extremely brittle?🛠
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287060
Sun Nov 11 2018 11:36 PM
ndkid275  Online
Northern VA
I will give the Formica a try.... where do I find it?
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287071
Mon Nov 12 2018 12:26 AM
Gord&Fran  Offline
Mill Bay, BC, Canada
You can get Formica at almost any hardware store.
I used Formica to make washers to go between the vinyl upholstery and the window and door cranks. I drilled holes in the Formica with a 2.25" hole saw. I then smoothed the edges of the cut outs and drilled them to fit over the shafts. The washers protect the vinyl upholstery from chafing.
We used plywood "door skins" for the panels. Thin foam was glued to the plywood and the vinyl stretched over and glued on the back side. It worked OK, but I like the suggestions above more. If you do use door skins, note that the plywood bends easier in one direction than in the other. Make sure you orient the plywood the correct way. Of course, we did it wrong. dang
Gord
1954 1/2 ton 235 4 speed
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287085
Mon Nov 12 2018 01:43 AM
ndkid275  Online
Northern VA
I may give it a try for roof and door skins. My skins and ceiling are falling apart after 1 year!
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287112
Mon Nov 12 2018 04:45 AM
Jon G  Offline
Dallas, TX
Formica is brittle but is more flexible than one might think. Please take a look at this scrap piece (which is 16" x 4") lying flat:
https://beta.photobucket.com/u/JonGoodman/p/67afae92-7408-4e27-8236-756b9c41d7cb
And here I have it sitting on a 2.5 inch tall piece of metal and I'm forcing it flat down on the table (making the bend around 30 ~ 35 degrees):
https://beta.photobucket.com/u/JonGoodman/p/de06daff-ddbd-4709-b4df-4bb67ff4979c
And here I am wrapping that same piece around the windshield trim molding (the one with the sharp bend):
https://beta.photobucket.com/u/JonGoodman/p/1fa19108-e620-48ef-bc04-e9696cff2e2b
As I said if you heat it with a blow dryer it becomes even more pliable. I'm certain there are instructions on the internet about this.
Jon
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287114
Mon Nov 12 2018 05:33 AM
ndkid275  Online
Northern VA
I plan on trying to cover it with something, probably black vinyl like my seats. We shall see how this goes, I am debating on making the roof one piece or 2 pieces. if I glue 2 pieces up there, I can still cover it easily, thoughts?
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287123
Mon Nov 12 2018 12:34 PM
sstock  Online OP
Gig Harbor, WA
Never though of formica, maybe that will even be better/cheaper than sheet aluminum, certainly cheaper for sure. Thinking of trying that on the roof panels because of the curves, thanks for that idea.
Building the roof panel in two pieces seems easier and will appear correct too. Plus you only handle and fit a smaller piece. Yeah, I'm really liking that idea. Thanks guys (Jon G.).
Re: Tired of Ugly Door Panels for AD Trucks [Re: Gord&Fran] #1287125
Mon Nov 12 2018 12:39 PM
sstock  Online OP
Gig Harbor, WA
Super idea for crank washers, liking this much better than the cardboard ones.
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287157
Mon Nov 12 2018 03:56 PM
52Carl  Online
Virginia
I may try to find aluminum sheet which is thin enough to fold the maroon vinyl over the edge, but still fit inside of the metal retainer. This will keep the vinyl from letting go of the glue and coming out of the edge of the retainer like mine always seem to do. The maroon vinyl which Jim Carter sells has extra material around the edge so that you could do this.
Carl
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287158
Mon Nov 12 2018 04:01 PM
ndkid275  Online
Northern VA
I found black Formica that I may try for roof so that I don’t have to put vinyl over it.
Re: Tired of Ugly Door Panels for AD Trucks [Re: ndkid275] #1287163
Mon Nov 12 2018 04:20 PM
Jon G  Offline
Dallas, TX
If you have the center bow and rear retaining cover for the headliner, everything will work as it should. That center bow has a front and rear slot and the rear retainer is held in place with screws. Cover the Formica or paint it before you install it. If you use vinyl, I'd try to use a thinner vinyl than what is on your seat. Then install the rear section first and secure it with the rear retainer. The bow will slip in place next. This requires a bit of coordination and a helper might be good also. Then slip the front piece into the front bow slot and secure it with the windshield trim after you get it in place. If you have a shade flap, measure and carefully cut the holes for it before you mount the panel (this can be difficult so do take your time). One way is to attach double sided tape (on which the holes have been cut out already) to the place on the body where the flap will mount, press the headliner panel in and then remove it to cut the holes. Hint: on the side of the double sided tape that sticks to the body...stick this somewhere on your face first. The oil will cause it to just "sort of" stick and then it will stick more firmly to the headliner panel when you remove it. Oh, and also...big important note...this job goes better if you remove the windlace and replace it once you're finished. It really is not fun trying to get the headliner panel on the other side of that windlace rubber.
Jon
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287800
Sat Nov 17 2018 05:40 AM
ndkid275  Online
Northern VA
Just purchased some Formica to see how well it works. Fingers crossed!
Chris
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287899
Sun Nov 18 2018 12:04 AM
Jon G  Offline
Dallas, TX
I'm sure you'll do fine. Here's a tip: get a jig saw (we used to call them saber saws also) and a fine metal cutting blade. Work carefully cutting the stuff and go slowly. If it is important to you to keep the front side from chipping when it is cut, get 1/4 inch plywood and clamp your Formica between two sheets of it. We used to do that for small or thin pieces. Did I mention go slowly?
Jon
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287916
Sun Nov 18 2018 01:01 AM
sstock  Online OP
Gig Harbor, WA
Good info Jon, for tight curves and the door and window crank holes use a dremmel.
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287985
Sun Nov 18 2018 07:29 PM
Rusty Shackleford  Offline
Vancouver, BC
I used black Formica/Aborite. I made a template of the panel with plywood, clamped the laminate to the plywood and used a router with a laminate bit with an edge guide. Because I needed black, I used the Formica as is.
It's a small world, but I wouldn't want to paint it.
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287996
Sun Nov 18 2018 10:15 PM
Hookalatch  Offline
Cottonwood, CA
Nice job on the door panels. I did basically the same thing on my 1952 3100. I did bend the aluminum to conform to the curve present in both my doors and door panel frames. It seems to be a much more pronounced crease in my truck then your 1953. I thought they were the same. I used the same covering as the seat and did take the vinyl over the edge. Tight fit in the frame but it worked. I have tried to attach a picture but not sure it will work.
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1288027
Mon Nov 19 2018 03:27 AM
Achipmunk  Offline
I'm even rethinking my panels................Steve, see what you got started.
52 Chevy Panel
Re: Tired of Ugly Door Panels for AD Trucks [Re: Rusty Shackleford] #1288042
Mon Nov 19 2018 04:41 AM
Jon G  Offline
Dallas, TX
That's right! If you have a router and a ball bearing laminate bit, it makes the work slick and quick. Just be certain to use the straight bit and not the edge bit...
Jon
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1288074
Mon Nov 19 2018 03:37 PM
MNSmith  Offline
So Cal
ABS here.
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1288142
Tue Nov 20 2018 02:34 AM
2ManyTrucks  Offline
california
nice door panels!
i was also concerned with the cardboard door panels i ordered online, so i did an intermediate fix, i just glued some old vinyl school bus seat material to the cardboard before installing the metal trim, time will tell if that's sufficient
but if i do it again i'm gonna go this aluminum sheet method, many more seats in the school bus to cut vinyl from, and two colors to choose from, grey or traditional brown smile
about the roof... yeah... i did such a bad job on the roof, but in my defense, it was my first one, i did it alone, it's a work truck so it didn't need to be show quality
i'm sure the second time will be much better smile
-s
1430s, 1420, 9430
-2MT
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1290459
Mon Dec 10 2018 01:11 AM
ndkid275  Online
Northern VA
I just cut and made the two roof panels in Formica. I might attemp to install the tomorrow night. I hope to get door seals in place so I can pick my wife up from the airport on the 20th. I will post pictures
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1290705
Tue Dec 11 2018 10:26 PM
HandyAndy  Offline
SE Iowa
Hey Chris,
Let's see those pics! I've been struggling with the door panels too. This past summer I replaced the door panels (purchased from a preferred vendor). They looked okay for a while, but the top corners kind of puckered when I tightened them. I just noticed the the driver's side panel is creeping out of the SS frame.
Are you guys over-sizing these custom made panels?
I appreciate all the dialog this thread has created. There are some great ideas out there on door panels.
Andy
His: 1947 Chevrolet 3100
Hers: 2008 American Saddlebred
"I may not have gone where I intended to go, but I think I have ended up where I needed to be." - Douglas Adams
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1290727
Wed Dec 12 2018 01:33 AM
ndkid275  Online
Northern VA
I am trying to get it put in ASAP. I am considering putting aluminum panels behind the Formica for the door panels to stiffen it up.
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1290748
Wed Dec 12 2018 04:17 AM
Jon G  Offline
Dallas, TX
Hint...if you're using fiberboard panels, consider putting a rubber faucet washer (3/4" diameter) behind each trim screw so the force of the screws doesn't pull them inward too much and deform them.
Jon
Re: Tired of Ugly Door Panels for AD Trucks [Re: Jon G] #1290981
Thu Dec 13 2018 10:18 PM
HandyAndy  Offline
SE Iowa
Jon G, thanks for the tip! In my case, I actually thought about something like that. At least my hindsight is 20/20!! wink
Andy
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1290988
Thu Dec 13 2018 11:15 PM
ndkid275  Online
Northern VA
Front panel is in! Looks great!
Edited: added pictures of back panel. I like it, not too bad, had one minor issue with mid measurement. The other was accidentally dropping the heat gun on my ankle. Had to yell without moving and dropping the panel. FYI, I yelled like a ****!
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1290998
Fri Dec 14 2018 12:45 AM
Jon G  Offline
Dallas, TX
That looks super! Good work and you didn't have to paint that, did you?
Jon
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1291001
Fri Dec 14 2018 12:55 AM
HandyAndy  Offline
SE Iowa
Nice work, Chris!
That really turned out great. Any issues with cutting the Formica? What did you use for the pattern?
Keep us posted on the door panels too. I've never cut sheet aluminum before and I suppose there's a preferred technique.
Thanks for sharing,
Andy
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1291013
Fri Dec 14 2018 03:09 AM
ndkid275  Online
Northern VA
So here is what I did.
Since I had cardboard that was falling apart, I used that as a template and adjusted it as needed since my truck isn’t square. Next, I used a drummel with cutting wheel to follow the line (very slow). Finally, held it close and heated the ends to mold it as needed. No painting!
Things I recommend. Make back panel longer due to cross member support. It slides in farther than I excepted. My cardboard must not have been slide in far enough.
If you get the 4x8 piece you can do both doors and roof panels.
I will post more once I do side panels. I am debating on doubling up Formica instead of aluminum.
Chris
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1291028
Fri Dec 14 2018 05:04 AM
ndkid275  Online
Northern VA
Anyone know how the cardboard kick panels are attached? Just curious since I have extra Formica that I might as well use.
Chris
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1291141
Sat Dec 15 2018 01:10 AM
Jon G  Offline
Dallas, TX
I don't know Chris. I've owned a few of these trucks and none had kick panels of any sort. They were all just painted. I always paint the interiors in catalyzed enamel or catalyzed urethane help keep from scuffing as much. The first one I saw with kick panels may have been in the early 1960s. A friend bought a 1965 brand new and got the deluxe model...it had A/C and kick panels. One of the nicest pickups I've ever seen until he traded it in on a 1968. Gas mileage was comically bad but you could ride in the thing all day long and not be tired.
Jon
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1291172
Sat Dec 15 2018 06:07 AM
ndkid275  Online
Northern VA
Jon,
I have mine painted, I was just curious to see what it would look like and how they actually did it.
Chris
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1291294
Sun Dec 16 2018 04:34 AM
ndkid275  Online
Northern VA
FYI, trying to get the visor screws in the right spot cracks the Formica easily!
Chris
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1291340
Sun Dec 16 2018 06:46 PM
MNSmith  Offline
So Cal
Time and vibration will end up doing the same.
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1291803
Thu Dec 20 2018 02:53 AM
HandyAndy  Offline
SE Iowa
Steve,
Nice work on those door panels. I'm basically in the same boat with my door panels. I've ordered the .050" aluminum and have the material to cover the panels. Here's a couple questions for you:
Did you cut the aluminum panel the same size as the cardboard? I was thinking about adding 1/16" all the way around to keep the panel in the frame.
Did you have to clamp the aluminum when you cut it with the jig saw? It seems like it could jump around a bit or wander.
Andy
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1291809
Thu Dec 20 2018 03:51 AM
sstock  Online OP
Gig Harbor, WA
No, the aluminum is cut the same size as the replacement cardboard door panels, I would be careful about cutting it oversize, worrying that the metal frame would not go around. I did clamp it along a piece of 3/4" plywood and used a fine tooth metal jig saw blade. Another thing I did that I forgot to mention was place 2ea 3/8"thick hard bumpers above each door handle mechanism to give it enough clearance between the sheet aluminum and handle mechanism,otherwise the door handle will not want to return on its own after opening the door. The other fellow above bent his sheet aluminum to fit over the door handle mechanism.
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1291941
Fri Dec 21 2018 10:17 PM
66flea  Offline
the arm rests are made of oak with the same merlot stain as the 3/8 beadboard
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1296283
Sat Jan 26 2019 02:00 AM
ndkid275  Online
Northern VA
Just got completed with the Formica door panels! Looks really good. Placed rubber washers behind it so I didn’t break it.
Chris
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1309888
Tue May 07 2019 01:07 AM
HandyAndy  Offline
SE Iowa
sstock, thanks for the tip!
The .050" aluminum really worked out nice for me. I still have quite a bit work to do on my interior, but this is a great start.
Andy
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1309902
Tue May 07 2019 02:16 AM
sstock  Online OP
Gig Harbor, WA
Well done Andy, looks so much better than cardboard.
Moderated by  Rusty46
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
