The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 registered members (klhansen, 52 Blue), 290 guests, and 3 spiders.
Forums48
Topics116,172
Posts923,798
Members42,360
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 3 of 6 1 2 3 4 5 6
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287123 Mon Nov 12 2018 12:34 PM
sstock Offline OP
Never though of formica, maybe that will even be better/cheaper than sheet aluminum, certainly cheaper for sure. Thinking of trying that on the roof panels because of the curves, thanks for that idea.
Building the roof panel in two pieces seems easier and will appear correct too. Plus you only handle and fit a smaller piece. Yeah, I'm really liking that idea. Thanks guys (Jon G.).
1953 Chevrolet 3100
261 cu inch, sm420, 3.55 rear, omaha orange, still 6 volt, RPO green glass, side carrier spare
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
Re: Tired of Ugly Door Panels for AD Trucks [Re: Gord&Fran] #1287125 Mon Nov 12 2018 12:39 PM
sstock Offline OP
Originally Posted by Gord&Fran
You can get Formica at almost any hardware store.
I used Formica to make washers to go between the vinyl upholstery and the window and door cranks. I drilled holes in the Formica with a 2.25" hole saw. I then smoothed the edges of the cut outs and drilled them to fit over the shafts. The washers protect the vinyl upholstery from chafing.
We used plywood "door skins" for the panels. Thin foam was glued to the plywood and the vinyl stretched over and glued on the back side. It worked OK, but I like the suggestions above more. If you do use door skins, note that the plywood bends easier in one direction than in the other. Make sure you orient the plywood the correct way. Of course, we did it wrong. dang
Super idea for crank washers, liking this much better than the cardboard ones.
1953 Chevrolet 3100
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287157 Mon Nov 12 2018 03:56 PM
52Carl Offline
I may try to find aluminum sheet which is thin enough to fold the maroon vinyl over the edge, but still fit inside of the metal retainer. This will keep the vinyl from letting go of the glue and coming out of the edge of the retainer like mine always seem to do. The maroon vinyl which Jim Carter sells has extra material around the edge so that you could do this.
Carl
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287158 Mon Nov 12 2018 04:01 PM
ndkid275 Offline
I found black Formica that I may try for roof so that I don’t have to put vinyl over it.
Re: Tired of Ugly Door Panels for AD Trucks [Re: ndkid275] #1287163 Mon Nov 12 2018 04:20 PM
Jon G Offline
Originally Posted by ndkid275
I plan on trying to cover it with something, probably black vinyl like my seats. We shall see how this goes, I am debating on making the roof one piece or 2 pieces. if I glue 2 pieces up there, I can still cover it easily, thoughts?
If you have the center bow and rear retaining cover for the headliner, everything will work as it should. That center bow has a front and rear slot and the rear retainer is held in place with screws. Cover the Formica or paint it before you install it. If you use vinyl, I'd try to use a thinner vinyl than what is on your seat. Then install the rear section first and secure it with the rear retainer. The bow will slip in place next. This requires a bit of coordination and a helper might be good also. Then slip the front piece into the front bow slot and secure it with the windshield trim after you get it in place. If you have a shade flap, measure and carefully cut the holes for it before you mount the panel (this can be difficult so do take your time). One way is to attach double sided tape (on which the holes have been cut out already) to the place on the body where the flap will mount, press the headliner panel in and then remove it to cut the holes. Hint: on the side of the double sided tape that sticks to the body...stick this somewhere on your face first. The oil will cause it to just "sort of" stick and then it will stick more firmly to the headliner panel when you remove it. Oh, and also...big important note...this job goes better if you remove the windlace and replace it once you're finished. It really is not fun trying to get the headliner panel on the other side of that windlace rubber.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287800 Sat Nov 17 2018 05:40 AM
ndkid275 Offline
Just purchased some Formica to see how well it works. Fingers crossed!
Chris
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287899 Sun Nov 18 2018 12:04 AM
Jon G Offline
I'm sure you'll do fine. Here's a tip: get a jig saw (we used to call them saber saws also) and a fine metal cutting blade. Work carefully cutting the stuff and go slowly. If it is important to you to keep the front side from chipping when it is cut, get 1/4 inch plywood and clamp your Formica between two sheets of it. We used to do that for small or thin pieces. Did I mention go slowly?
Jon
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287916 Sun Nov 18 2018 01:01 AM
sstock Offline OP
Good info Jon, for tight curves and the door and window crank holes use a dremmel.
1953 Chevrolet 3100
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287985 Sun Nov 18 2018 07:29 PM
Rusty Shackleford Offline
I used black Formica/Aborite. I made a template of the panel with plywood, clamped the laminate to the plywood and used a router with a laminate bit with an edge guide. Because I needed black, I used the Formica as is.
It's a small world, but I wouldn't want to paint it.
Re: Tired of Ugly Door Panels for AD Trucks [Re: sstock] #1287996 Sun Nov 18 2018 10:15 PM
Hookalatch Offline
Nice job on the door panels. I did basically the same thing on my 1952 3100. I did bend the aluminum to conform to the curve present in both my doors and door panel frames. It seems to be a much more pronounced crease in my truck then your 1953. I thought they were the same. I used the same covering as the seat and did take the vinyl over the edge. Tight fit in the frame but it worked. I have tried to attach a picture but not sure it will work.
Moderated by  Rusty46
Powered by UBB.threads™ PHP Forum Software 7.7.3
