The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
21 members (5 Window 9434, clarsen3100, 95Z28A4, ApacheFiend, BC59, Brad Allen, 1 invisible), 308 guests, and 5 robots.
Forums50
Topics121,476
Posts973,865
Members43,939
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Engine max RPM
#1285155 Sun Oct 28 2018 02:37 AM
Jolly Roger
Now that I’ve gotten the engine running to factory standards, the question of overrev comes into play. I know it doesn’t have a governor but it also isn’t VVT so overrev wouldn’t hurt more than the bearings over a long period. I know the highway going 45 cruising RPM is something like 3500-3800. What I want to know is what will the engine run at with full throttle in neutral and what would be considered red lining it. Also how much damage would be done to it if it is ran at full throttle for a few seconds.
Owner of the most temperamental 1951 3100 in existence
Re: Engine max RPM
Mr. Dane #1285159 Sun Oct 28 2018 02:49 AM
Boltergeist
Running full throttle at no load is a surefire way to do major damage to the rod bearings of any engine. If you're running a 216 with cast iron pistons, that's a very good way to hammer the Babbit bearings into nothing in a very short time. The engine will run pretty much forever at 3500 or a little more as long as it's done while pulling the vehicle. Revving it up in neutral is an exercise in stupidity.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Engine max RPM
Mr. Dane #1285173 Sun Oct 28 2018 06:52 AM
Mr Dane has a '54 235 in his 1/2 ton . Great engine .
but 3800rpm at 45mph ??? need a new rev counter .
RPM Calculator; http://www.csgnetwork.com/multirpmcalc.html
Re: Engine max RPM
Mr. Dane #1285188 Sun Oct 28 2018 01:20 PM
ace skiver
Maybe in 2nd gear with the heavy duty 3-speed (3.90 rear) = ~3800 rpm
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: Engine max RPM
Dusty #1285230 Sun Oct 28 2018 07:57 PM
Jolly Roger
i dont think its hitting 3800 thats just what i saw in another form post. i need a rev counter as it stands lol
Re: Engine max RPM
tclederman #1285231 Sun Oct 28 2018 07:58 PM
Jolly Roger
its just got a stock 4.11:1 that came on the 1/2 tons.. so from what ive read on other sites it could be somewhere from 3200-3800. either way thats a pretty good running speed..
Re: Engine max RPM
Hotrod Lincoln #1285232 Sun Oct 28 2018 08:03 PM
Jolly Roger
hopefully that'll never happen. ill just make sure im the only one that drives it.
Re: Engine max RPM
Mr. Dane #1285233 Sun Oct 28 2018 08:04 PM
Jolly Roger
anyway ive found what im looking for thank you all for the help!
Re: Engine max RPM
Mr. Dane #1285962 Sat Nov 03 2018 09:08 PM
Standard 1/2 ton? Stock trans ans rear end? And a 235? That is the same setup I have in my 52. With a decent tach on the column I read 3000 RPM at 60 MPH. 235 15 tires and wheels. So, try to get a good reading on the engine RPM. My truck sounds "busy" at 2500/2700 RPM(that is close to 55 MPH) so I do tend to stay right around that speed. It will go as fast as 65, but neither me or the truck feel real happy for long at that speed. I do some "freeway" driving. Not avoidable in Utah, but I don't go far from the right hand lane. Hot Rod thinks 3500 is fine. Trust him. Here is one, kinda spendy but a good counter: https://www.autometer.com/2-5-8-tach-4-000-rpm-low-rev-black.html
Steve H
Re: Engine max RPM
Mr. Dane #1285970 Sat Nov 03 2018 10:12 PM
Boltergeist
235's from 54-62 were factory max HP rated at speeds from 3800-4200, depending on the year of the engine. With good rod bearings and good oil pressure, these engines will stay together and produce more HP than most of us will ever need at speeds we're afraid to approach. If an engine is noisy at lower speeds, it's either worn out, or we're just not accustomed to hearing one earning its keep at its HP-rated RPM. The bigger trucks with plenty of gears got run at or near redline pulling max loads or above all day and stayed together.
Moderated by  Woogeroo
