The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (AlanV, carbking, drdoug, Chooglin, Greg_H, 1 invisible), 301 guests, and 3 robots.
Forums50
Topics121,474
Posts973,858
Members43,939
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Front motor mount assembly, slots up or down? 48-3609
#1284298 Sun Oct 21 2018 03:26 AM
I read about putting slots up, but not in Gm manual i can find??? Heres mine coming out of holder, slots down..... i believe its original from factory as this thing was parked in 1977 and barn stored since. So do i put slots down or up tomorrow?
https://postimg.cc/gallery/2y4dwtrk6/
Heres whats left of the rear mounts.
https://postimg.cc/gallery/1zeu31zgm/
Re: Front motor mount assembly, slots up or down? 48-3609
wrenchguy #1284400 Mon Oct 22 2018 12:08 AM
Fig 20 in the manual, shows the "slots" up. The cross section is not too tough to see. Thanks to the Old Online Chevy Manual Project.
Steve H
wrenchguy #1284471 Mon Oct 22 2018 02:16 PM
I noted that some time ago, with all the details in that illustration, slots weren't indicated with arrows or text like everything else was. I don't think it makes a difference so i put my slots down. Thanks 4 bring it up.
wrenchguy #1284477 Mon Oct 22 2018 02:50 PM
Years ago I removed one I know had never been changed (this being around 1975 or so) and the slots were facing down. I made myself a note of it since it differed from the shop manual and that's how I've done it since. Just be certain to use the right washers on the bottom side since larger ones can stop all movement and you don't want that.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Jon G #1284495 Mon Oct 22 2018 04:45 PM
Right!, i changed my originals with new, they are sae's and mine were badly battered, hammered and been through the wringer!
Must be alot of forces in action down there.
wrenchguy #1284924 Fri Oct 26 2018 12:46 PM
re; Hammered center bolt washers.
Heres a photo of the 1's i took out, i believe they're original to day built. The od measures rch more than 13/16". Remember these nuts & bolts are tight to 7/16 nft torque specs. They are not compressing the mount rubber like the outboard bolts are. Outboard bolts are snug tight only.
washers, https://postimg.cc/gallery/2a2hxsvnq/
wrenchguy #1285019 Sat Oct 27 2018 12:49 AM
We sent a man to the moon. Some of those guys probably worked on a Stovebolt truck or two.
Why can't someone come up with a simple design, modern material motor mount?!
Moderated by  SWEET
