The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
A lovely month ...
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 registered members (66flea, capnduane, BJF52, 1951Chevy1Ton, DennisM, 63stepsideLB), 241 guests, and 3 spiders.
Forums47
Topics113,320
Posts898,698
Members41,594
Most Online940
Apr 5th, 2017
Image Posting Policy
AC Oil Filter Assy Available? #1283274
Thu Oct 11 2018 04:54 AM
57Pikkupp  Offline OP
Northern California
I just read the tech tip on oil filters. I have a '57 235 without an oil filter, which I'd like to add. Does anyone sell a reproduction of the correct AC filter housing , filter, brackets and lines?
Re: AC Oil Filter Assy Available? [Re: 57Pikkupp] #1283275
Thu Oct 11 2018 05:01 AM
Hotrod Lincoln  Online
Boltergeist
Dellrose, TN
Thee are thousands of originals out there- - - -no real need for a reproduction. Check Ebay for listings. There are usually several available, and the prices aren't outrageous. Some of the resto-ripoff places sell the correct decals, etc.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: AC Oil Filter Assy Available? [Re: 57Pikkupp] #1283278
Thu Oct 11 2018 05:21 AM
bartamos  Offline
State48 Ranch
Agree with getting an original filter housing and brackets. (Donor markets: Stovebolt parts for sale/wanted, Ebay, Craigslist, swap meets, etc.). New lines are available for $30. Element (cartridge) sold everywhere also.
1960 GMC K1001 (The Oreo SpeedWagon)
To each his own or the Highway.
All I know is what the voices in my head tell me and a little from watching TV.
Re: AC Oil Filter Assy Available? [Re: 57Pikkupp] #1283352
Fri Oct 12 2018 04:27 AM
Northern California
Thanks, HRL and Bartamos, I'll start checking ebay, etc. I think I'l need one as my oilpan had literally about a 1" thick layer of sludge in it ;-)
Re: AC Oil Filter Assy Available? [Re: 57Pikkupp] #1283357
Fri Oct 12 2018 11:47 AM
dgrinnan  Online
Northern Kentucky
The oil from the period of these trucks did not have the detergents like modern oil. The sludge would settle in the pan and that is how they got away with no oil filter. Not sure if it is true but I have heard that a common problem experienced when bringing an engine back to life after it has been sitting for decades is the new detergent oil will break up the sludge in the pan and re-introduce it back into the oil. It is critical that you drop and clean out the pan when attempting to resurrect an engine in that old barn find.
My 54 235 did not have an oil filter originally. One of the lines in the line set I bought was too short. I searched and searched and could not find a line that would work. The fitting size was wrong on everything I found. I ended up making my own. I went to Advance Auto. They have a larger in store selection of brake line fittings than Auto Zone. I purchased a length of the copper-nickel brake line. It is more flexible than the steel. I bought the correct combination of fittings. It required me to incorporate an adapter fitting. They did not have a fitting that would work with the flare connection directly to the oil canister fitting. (You will need a flare tool)
When I bought the canister it was covered in surface rust. I soaked it overnight in vinegar. The next day it scrubbed up great and was ready for paint.
I did get the decals from classicparts.com
I did mine in the AC color scheme. Frame is black and yellow/ I am sure there are variations depending on the year and make.
The blue and orange paint are Chevy Orange and Chevy Blue.
Oil Filter on engine
Oil filter
Stove Bolt oil filter tech tips
Dave from Northern Kentucky
My 54 3100
Re: AC Oil Filter Assy Available? [Re: 57Pikkupp] #1283363
Fri Oct 12 2018 01:47 PM
Boltergeist
Dellrose, TN
The fittings in the canister are 1/8" female pipe thread. (1/8 NPT). The original equipment flex lines have one 1/8 NPT rigid fitting that screws into the block port, and a swiveling 1/8 pipe thread that attaches to the filter. If you choose to use rigid lines, you'll need adapters from 1/8 NPT male to 1/4" "inverted flare" female, to match the fittings on the copper-nickel 1/4" brake lines.
Re: AC Oil Filter Assy Available? [Re: 57Pikkupp] #1283373
Fri Oct 12 2018 02:55 PM
Northern California
Wow, great information dgrinnan and Hotrod. Thank you, that will save me time and hassle - love these Stovebolt forums! Now, to find a canister... and, yes, I did remove all of the old sludge from the oil pan; and saw the metal shavings in there too ;-)
Moderated by  53moneypit, Woogeroo
Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
