The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
A lovely month ...
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
23 registered members (cmayna, 3B, Bill Marlow, 68ironhead, 5 Window 9434, bluesman, 1 invisible), 223 guests, and 3 spiders.
Forums47
Topics113,320
Posts898,690
Members41,594
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 2 1 2
Re: 1946 1.5 ton with 9ft bed [Re: GarlandFarms] #1282223
Tue Oct 02 2018 11:46 AM
EdPruss  Offline
Longmont, CO
I have some 8 lug wheel spacers. Easy to make some 10 lug, just labor.
Ed
Re: 1946 1.5 ton with 9ft bed [Re: GarlandFarms] #1283286
Thu Oct 11 2018 01:05 PM
stouchton  Offline
Pottstown PA
May I ask how you intend to mount the lumber to the frame? I am pondering a similar modification in the future, but to a flat bed. Have a few ideas, but not sure what the "right/easy" way is. Thanks.
Re: 1946 1.5 ton with 9ft bed [Re: GarlandFarms] #1283358
Fri Oct 12 2018 12:30 PM
whateverpratt  Offline
Deltona, FL
Man that looks good.
I'm hoping to do that with an advance design 4100 or 6100 some day ( I have the front clip, cab, and bed, just need the frame)
'66 c10 rust bucket, 350 nv4500 stock bellhousing, converting to 1 ton suspension
'67 cj5 225 oddfire, need to add overdrive
'48 3804 frame and bed + '52 6400 cab and front clip, need to put them together
Re: 1946 1.5 ton with 9ft bed [Re: GarlandFarms] #1283556
Sun Oct 14 2018 06:42 AM
Lionelgee  Offline
Queensland Australia
Hello Scott,
It is a great looking truck! Could you please take some photographs of the inside of the cabin showing how the windscreen is tilted up? How far can the windscreen tilt up?
I just posted a thread about tilting windscreens - ID WWII Truck...
Kind regards
Lionel
Re: 1946 1.5 ton with 9ft bed [Re: Lionelgee] #1283737
Mon Oct 15 2018 09:15 PM
GarlandFarms  Offline OP
Colorado
Thanks, Here are some older photos of the truck with the front window open.
Re: 1946 1.5 ton with 9ft bed [Re: GarlandFarms] #1283971
Wed Oct 17 2018 08:23 PM
Grizzly 34s  Offline
Crystal River, FL
The 9' bed looks good on your truck. I would like to do that also on my 1935 1 ton.
"Save your's or someone else's Grandfather's CLASSIC TRUCK"
1934 1.5-Ton Big Bolts ~ Gallery page / Photobucket
Re: 1946 1.5 ton with 9ft bed [Re: GarlandFarms] #1284357
Sun Oct 21 2018 06:45 PM
Colorado
Thanks, I borrowed a driver side A-D fender from a neighbor. Locally, I'm looking for a pair of my own.
Re: 1946 1.5 ton with 9ft bed [Re: GarlandFarms] #1284884
Fri Oct 26 2018 12:43 AM
Deltona, FL
If you aren't concerned with original sheet metal, you can get reproduction advance design fenders on rock auto for ~$300 each
Re: 1946 1.5 ton with 9ft bed [Re: GarlandFarms] #1291566
Tue Dec 18 2018 03:57 AM
Colorado
Getting closer*. The gas tank needs to be pulled and cleaned, lots of rust keeps getting past the filter (just put in a new one and it's already getting rust bits in it).
While I'm doing that, I'm going to pull the bed, weld in the inner fender and then mount the bed on the frame.
Here's a one minute video of the truck from a few angles....
https://youtu.be/u9Jd8kFvDBM
*thanks to Wheelie for the shifting housing, fixed my gear grinding and popping out of gear.
Page 2 of 2 1 2
Moderated by  69Cuda, Grigg
Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
