Report out guys on using this for a repair. I've always been a skeptic, however recently did a repair on a door panel and pleased to report this is pretty good stuff. Tough as well. The hardest part for most of us, will be the required color mixing. The kit provides some guidance on colors needed to match your project, but it takes some practice. So if you have a seat tear, an arm rest, etc. give it try for $15 bucks. Heck of lot cheaper than a new replacement part.
Allen
1945 Ford 2N Tractor - Runs great, Will restore when run out of other projects
1974 Stingray Corvette
