The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
A lovely month ...
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
23 registered members (Apache1, Bill Marlow, 3B, 68ironhead, 5 Window 9434, bluesman, 2 invisible), 242 guests, and 3 spiders.
Forums47
Topics113,320
Posts898,690
Members41,594
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
BUY ONE or MAKE ONE? #1282877
Mon Oct 08 2018 01:23 AM
Lugnutz  Offline OP
South Carolina
I need one more safety stand for my lift. I own one but I need another one.
I was given some old boat stands, so I have the parts to make another one. The screw portion is not as long as my Matco stand, but I think I it will be long enough.
To fabricate one from some old boat stand parts will take a little bit of time, but I will get to practice my welding. I might even try TIG.
These stands serve as supports to prevent the vehicle from rocking on the lift arms (when installing or removing a transmission, or when using a pry bar etc.)
Am I crazy to fabricate my own? Any design ideas for the base? The screw basically slides inside the pipe and rests on the wing nut.
Here's a LINK for pics.
Re: BUY ONE or MAKE ONE? [Re: Lugnutz] #1282878
Mon Oct 08 2018 01:49 AM
Hotrod Lincoln  Online
Boltergeist
Dellrose, TN
Use the complete boat stands, but get the pipe vertical and reduce the triangular footprint so you don't take up so much room under your lift. You'll need to extend the short leg enough to make the pipe stand straight up, then fabricate new braces to stabilize the triangle. Make the footprint about half what it is now, and use a carpenter's 4 foot level to make sure the pipe stays vertical while you're tacking up braces. I think Denny Graham posted some pics of similar stands he made, with folding legs for storage.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: BUY ONE or MAKE ONE? [Re: Hotrod Lincoln] #1282928
Mon Oct 08 2018 02:13 PM
Grigg  Offline
Lexington, VA
...Denny Graham posted some pics of similar stands he made, with folding legs for storage.
https://www.stovebolt.com/ubbthread...3289/under-lift-stands-that-fold-up.html
1952 Chevrolet 3800 pickup
---All pictures---
Re: BUY ONE or MAKE ONE? [Re: Lugnutz] #1283645
Mon Oct 15 2018 02:20 AM
Lugnutz  Offline OP
South Carolina
I've finished this project.
Safety Stand - ALL the pictures.
Paint is drying. Still needs a rubber pad on top.
It's not as nice as the stands Denny Graham made, but I didn't want to make him feel bad. LOL!
I butt welded 2 pipes together. The screw is not as long as my Matco stand, so the pipe had to be taller. An old release bearing makes a perfect bearing to position beneath the wingnut.
I made a novice welding mistake. When making the base, I got the round plate too hot when welding and it warped. So the base plate was warped.
To fix this, I made a relief cut. That cured the problem and then I took my time welding the relief cut closed.
I figured this project would give me a chance to practice TIG welding. I did OK when I tried to TIG the pipe - end to end. That's because it was an OUTSIDE surface weld. I tried to TIG some inside corners but that did not go well at all. That was cut apart and then MIG welded - which looked much nicer. I'll need to practice TIG some more.
Re: BUY ONE or MAKE ONE? [Re: Lugnutz] #1283768
Tue Oct 16 2018 01:23 AM
52Carl  Offline
Virginia
For welding inside corners with TIG you can cheat by extending the tungsten out further so that you have it closer to the weld without the ceramic getting in the way.
A good way to setup for these situations is by going through the motions of the weld in a dry run without stepping on the pedal. Make sure you can keep the tip of the tungsten close to the metal without the ceramic making contact. Then you are ready to go. Don't worry about the argon shield going away unless its windy or because you have a fan blowing because you live where it is as hot as Mississippi.
Carl
Re: BUY ONE or MAKE ONE? [Re: Lugnutz] #1283804
Tue Oct 16 2018 12:29 PM
Lugnutz  Offline OP
South Carolina
Carl,
Thanks. I need to stand next to someone who can TIG, and watch over their shoulder. I also need to practice. I’ll keep at it.
Re: BUY ONE or MAKE ONE? [Re: Lugnutz] #1283839
Tue Oct 16 2018 05:46 PM
Boltergeist
Dellrose, TN
One kind of welding that's virtually never done (or taught) any more is OAW (Oxy-acetyline welding) Most people call it "brazing" but back in the dark ages when I learned, we actually fused steel with a torch and a bare steel fill rod, without using brass or bronze as a filler metal. Once you can make smooth full-penetration welds with an acetyline torch, doing it with TIG comes second nature, because the process is almost the same. The only difference is that you're using an argon-shielded arc instead of a flame to create the puddle.
Re: BUY ONE or MAKE ONE? [Re: Lugnutz] #1283886
Wed Oct 17 2018 02:18 AM
Lugnutz  Offline OP
South Carolina
If I can find a reasonably priced OAW setup, I plan on buying one. I have limited space, so in the meantime I’ll just keep practicing TIG until I get better.
Re: BUY ONE or MAKE ONE? [Re: Lugnutz] #1283968
Wed Oct 17 2018 07:54 PM
klhansen  Offline
Eagle River, Alaska
The regulator/hose/torch setup isn't that expensive ( I bought a decent Lincoln Electric set at Lowes for under $200), but the gas bottles were way more than that.
The HF setup is an option for less money, but I've heard that the hoses are crap and need to be replaced right away.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck.
Re: BUY ONE or MAKE ONE? [Re: Lugnutz] #1283974
Wed Oct 17 2018 08:46 PM
Boltergeist
Dellrose, TN
Hoses are a fairly minor expense. The cost-controlling factor will be the quality of the regulators. Victor has been the industry standard for torches for a long time, with "Smith's" a close second. A good set of 2-stage oxygen and acetyline regulators will cost as much as the rest or the hoses, mixing chambers. torch tips, etc. and good regulators will make moderate-quality other components work well. Most of the imported torch sets sold by HF, Northern Tools, and other mass merchandisers are clones of a Victor setup with cheap to mediocre quality regulators.
Page 1 of 2 1 2
Moderated by  48bigtrucks, MNSmith
Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
