The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 registered members (carryall jerry, Drew54, 49 3100, bigblack'74, Shox Dr, Justhorsenround), 277 guests, and 3 spiders.
Forums47
Topics114,621
Posts909,408
Members41,974
Most Online940
Apr 5th, 2017
Image Posting Policy
1949 Suburban w/235 engine #1281762
Fri Sep 28 2018 04:45 PM
Canuto Martinez  Offline OP
Moderated
San Diego, California
Hello all,
I am new to this process and have a question for anyone out there who can help. I am restoring a 1949 Suburban and have a question regarding the heater configuration. I have a Harrison heater which is intact but I need to determine which hose should I install the shutoff valve so no water will go into the heater. The heater is not going to be used, it is just for looks.
Thanks for your help - Canuto Martinez
Canuto
Re: 1949 Suburban w/235 engine [Re: Canuto Martinez] #1282047
Mon Oct 01 2018 03:01 AM
Mother.Trucker  Offline
Skull Valley AZ.
Here is the correct hose routing for the Harrison Fresh Air Heater.
Re: 1949 Suburban w/235 engine [Re: Canuto Martinez] #1282112
Mon Oct 01 2018 05:32 PM
Cosmo  Offline
ODSS President
CHARLOTTESVILLE
Canuto, welcome to the site. You'll find your way around and start to explore by doing SEARCHES for subjects and problems you are having. You will also find FORUMS to be helpful in addressing specific problems like ENGINE and DRIVE TRAIN.
Having put over 110k miles on a '49, in addressing your , "...which hose should I install the shutoff valve so no water will go into the heater." I have found that I need to shut off BOTH in a non-stock after market heater. The reason is that even though the flow cannot occur with a shut-off on either hose, migration of heat via the hose that is not shut off will occur.
You have a temperature control valve which should if operating correctly open only when you want it to. I would think a single shut-off on the other hose coming off the water pump would keep water out of your heater radiator, thereby keeping heat out of the cab..
Be patient with us, we include the whole gamut of the population.
Cosmo
"...my good horse Rozinante ('49 Chevy Half Ton), mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes
Re: 1949 Suburban w/235 engine [Re: Canuto Martinez] #1282224
Tue Oct 02 2018 11:47 AM
John Milliman  Offline
Founder/Developer
St. Mary's Co., MD
Indeed! Welcome Canuto! Sorry about the confusion earlier. We're glad you're here. We don't see enough 'Burbs! Got pictures?? smile
'49 Chevrolet 3804
'70 Boston Whaler Sakonnet w/ '84 Evinrude 90
'85 Ford F-350 "The Farm Dawg"
Re: 1949 Suburban w/235 engine [Re: Cosmo] #1282249
Tue Oct 02 2018 02:46 PM
Moderated
Cosmo,
Really appreciate the info.
Thank you - Canuto
Canuto
Moderated by  J Lucas
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
