The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 registered members (drdoug, matthews940, 55 SHAKER, beltfed, Brad Allen, cmayna), 303 guests, and 3 spiders.
Forums47
Topics116,101
Posts923,136
Members42,336
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 3 of 3 1 2 3
Re: Trying to squeeze out a little more gas mileage [Re: Jeff Ogden] #1311163 Sun May 19 2019 04:56 PM
Joe H Offline
Took mine out for a drive after cleaning the carburetors. Local highway, slight up and down, no major hills but not flat either.
250 inline 6, dual W-1 Carters, 3.08 gear, T350 auto trans with 1:1 output, 28" tall tire, 3300 lbs, 18.5 vacuum at idle (600 rpm)
At 65 mph, on the level, 11 - 12 on the vacuum gauge, 16.5:1 on the A/F ratio, 2450 rpm.
At 65 mph, up hill, 9 on vacuum gauge, 15:1 A/F ratio, 2400 rpm
At 70 mph, down hill, 14 on vacuum gauge, 17:1 A/F ratio, 2450 rpm.
This is the same it ran last year, got 21 mpg on a 300 mile trip.
Re: Trying to squeeze out a little more gas mileage [Re: Jeff Ogden] #1311169 Sun May 19 2019 05:20 PM
Hotrod Lincoln Offline
Boltergeist
Good gas mileage- - - - -but what's the piston mileage on one running that lean? You're right on the ragged edge of destructive detonation, especially if the ignition timing is advanced just a tiny bit above optimum. Gasoline is cheaper than engine parts!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Trying to squeeze out a little more gas mileage [Re: Jeff Ogden] #1311206 Sun May 19 2019 11:48 PM
Joe H Offline
I can run a fair bit more timing and lean due to the 8.0:1 compression. On average, the A/F ratio is much lower, these numbers are just when I looked at the gauge. It would need to be graphed out to see the true average.
Page 3 of 3 1 2 3
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
