EVENTS
Check in for status!
Jump over to the
Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
17 members (Bill Marlow, Arne, Forty9, DennisM, Donf, Gazz, 3 invisible),
244
robots. |
Key:
Admin,
Mod
Forums50
Topics122,184
Posts980,142
Members44,168
Most Online1,229 Jan 21st, 2020
 Ammeter Testing
OP
OK, just when I think I'm getting a handle on all things electrical I run head first into something that doesn't work even though I think it should. I have 3 extra ammeter gauges in my pile of old parts and I'd like to use one of them in Speedy, my '48 GMC, where I'm replacing the modern gauge cluster with an original style one. I've managed to Frankenstein a cluster together, refacing the gauges as I go, but before I reface and install the ammeter I want to make sure that it works . I thought I would enlist the help of my '48 Chevy truck, Pokey, by carefully attaching jumper wires from his working ammeter to the terminals on the ammeters I want to test. I do,but nothing happens on the gauge I'm try to test though the gauge in the dash works fine. Is this a method that should work to test the gauge or is it completely stupid? Wouldn't be the first time for me! Thanks, Jim
 Re: Ammeter Testing
Boltergeist
Easy- - - -just connect two fairly large wires, #12 of bigger to the ammeter and use it to power something like a headlight, a heater motor, or some other device that will draw enough current to see the needle deflect. Reversing the direction of flow through the wires will make the needle deflect toward the + or - direction. When current flow stops the needle should return to center. You are aware that dash mounted ammeters are about as accurate and trustworthy as political promises, aren't you? Jerry
The murder victim was drowned in a bathtub full of Rice Krispies and milk. The coroner blamed the crime on a cereal killer! Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
 Re: Ammeter Testing
spot on jerry, as all ways . i run all my power threw my amp meter , so i can see all draw threw the hole system
 Re: Ammeter Testing
OP
Jerry, I don't care about the numbers on the ammeter, just charge or discharge is all I'd like. I can test the gauge the way you mention, I'm just wondering why my jumper wire method didn't work. I guess the redundant gauge doesn't get any current flowing through it. And I do apply a heavy discount to political promises.
Jim
 Re: Ammeter Testing
Boltergeist
You were running a parallel circuit- - - - -the original ammeter had a better connection, probably one with lower resistance, so virtually all the current followed that path. Basic Ohm's Law! You would have to put both ammeters in series with each other for your test method to work. Jerry
 Re: Ammeter Testing
OP
