The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (klhansen, kevinreabe, 1 invisible), 105 guests, and 3 robots.
Forums60
Topics125,427
Posts1,012,788
Members45,231
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Amp guage reading backwards. Read on..
#1279276 Thu Sep 06 2018 02:09 AM
Here goes.
261 engine 12 volt.
decided to go ahead and hook up the generator Saturday and before doing this I checked the battery. I had used it a time or two and the voltage was 12.8
I hooked up the generator and checked at the battery and it indicated the generator was charging at 13.8 so all was good. However, the amp gauge reads backwards. I reverse the wires at the generator and check at the battery and it is not charging there so I switched the wires back on the generator.
What do you guys think? does the generator need polarizing? I've heard of folks doing that.
Comments please....and beware I may not be back here for a few days. I have a lot on my plate right now but will get back soon. Thanks
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
52 Chevy Panel [photos.app.goo.gl]
Pictures in my Photobucket [s140.photobucket.com]
https://photos.websearch.com/share/...Nko1cUJCNFFMTVFEUnNRbjFhNTFPc1J4YWV4cmRB
Re: Amp guage reading backwards. Read on..
Achipmunk #1279279 Thu Sep 06 2018 03:04 AM
Bubba
Alvin,
Yes, the generator needs polarizing.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Achipmunk #1279326 Thu Sep 06 2018 02:49 PM
The generator is good. Swap the wires at the ammeter terminals. There should be only one heavy gauge wire going from the ammeter to the battery cable connection at the starter, and all the other circuits such as the ignition switch, fuse block, headlight switch and regulator "BAT" terminal wire should attach to the other terminal. Some ammeters have one long stud made to accommodate several terminals.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Achipmunk #1279750 Mon Sep 10 2018 08:46 PM
This may be a long shot and is more likely on positive ground cars.....Many years back I purchased a positive ground Ford where the ammeter read backwards. The owner said not to worry, that was just the way the gauge worked - stupidly I believed him. After some time I noticed that the battery was installed backwards! I switched the battery to the proper positive ground and the ammeter then read correctly. Oddly I never noticed any difference in the performance either way. If I hadn't experienced it I would have thought the car would not run with a backwards battery but it did.
Moderated by  Rusty Rod
