The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 registered members (53 green 1- ton, 52Carl, clarsen3100, 2ManyTrucks, 4112YR, 47bolter, 1 invisible), 329 guests, and 3 spiders.
Forums48
Topics117,294
Posts937,766
Members42,883
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Spun bearing info needed #1278097 Tue Aug 28 2018 01:08 AM
46Sparky Offline OP
I know diddly about this stuff, so help me understand what the term “spun bearing” means? Inquiring minds want to know, please.
What is it?
What causes it?
How is it avoided?
How is it fixed?
Thanks in advance.
Re: Spun bearing info needed [Re: 46Sparky] #1278100 Tue Aug 28 2018 01:29 AM
Hotrod Lincoln Offline
Boltergeist
That term gets misused pretty often to describe any sort of bearing failure. When it actually happens, a bearing such as a connecting rod or main gets worn thin enough that the ends of the bearing overlap, one bearing slides under the other, and wedges itself tight enough that the crankshaft usually locks up. If this happens to a connecting rod, the rod will sometimes break and the broken-off piece spins around inside the block. That brings on another misused term- - - -"thrown rod". That usually ends up with holes in the block and/or the oil pan. Occasionally, an engine will keep running if the spun bearings are worn badly enough that they don't wedge together. The knocking noises from a bearing that bad are horrendous! By the time a bearing gets loose enough to knock heavily or spin, the fix usually involves installing another crankshaft, and replacing or reconditioning all the connecting rods.
When an engine starts losing oil pressure and making lower-end noises, some people do their best to ignore them, hoping the problem will go away. That's like being just a little bit pregnant!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
