The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (Achipmunk, 55shaker, 52Carl, Adamg, 55_2nd_Series, 5 Window 9434), 165 guests, and 3 robots.
Forums60
Topics123,945
Posts1,000,278
Members44,788
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Cordless Magnetic Work Light
#1274626 Wed Aug 01 2018 06:56 PM
I'm just looking for some recommendations about which one or ones you have used and like. Any preference between battery and rechargeable? LEDs best? Bigger is better? Thanks in advance. Jim
Re: Cordless Magnetic Work Light
Eureka Jim #1274636 Wed Aug 01 2018 07:39 PM
Rechargeable - good idea
LED - good idea
I have bought cheap one of various sizes, with hanging hooks and magnets - from Harbor Freight, Northern Tools, Jegs, etc
I have never had one go bad (all foreign manufacture, no doubt).
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Eureka Jim #1274640 Wed Aug 01 2018 08:05 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
I use the coupon from Harbor Freight to get the free magnetic/hanging LED work light. As Tim says work good and no problems. For larger jobs I would probably go with a professional rechargeable light.🛠
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
Eureka Jim #1274648 Wed Aug 01 2018 09:59 PM
https://www.harborfreight.com/27-led-portable-worklight-flashlight-67227.html
144 lumens - 27 LEDs - magnetic
mine is at least 6 years old
https://www.harborfreight.com/215-lumen-pocket-worklight-63935.html
Other HF LED work lamps.
I got 2 of these about 6-7 years ago.
They are bright and they are handy and they are rechargeable - they are long - good under the hood, but unwieldy in tight places..
Tim
Eureka Jim #1284511 Mon Oct 22 2018 08:00 PM
I've been using a Pelican LED flashlight with an adjustable head and STRONG magnet recently. The angle head works well with the light stuck to the sheet metal.
Light
I probably wouldn't have bought it myself, but someone gave me a gift card that I had to spend. wink It's intrinsically safe, so you could use it while doused in gasoline big_eek and wouldn't make things go boom! It uses AA batteries. I've found that rechargeables are sometimes hard to get when they finally go bad.The only thing I don't like about it is that getting it to change from spot to flood takes a bunch of tries clicking the on-off switch (timing is touchy). It defaults to both LED's on, which sucks the batteries down a bit faster than just one.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Eureka Jim #1287563 Thu Nov 15 2018 06:16 PM
Workshop Owner
With Black Friday a week away, I too am looking for a good deal on a good LED rechargeable work light. I have a Black & Decker- Bright Bar and it is finally on it's last legs. It has been a good light for me as I ended up buying two (one at work and one for home). The weak point is the batteries and charger. If you overcharge it, it will kill the battery.
To me, an ideal light would be very similar to the Bright Bar, but would use a battery from a drill or similar rechargeable tool.
J Lucas
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
1959 Chevy Apache 31 Fleetside
1959 Chevy Apache 32 Fleetside
1959 Chevy Viking 40
My Flicker Photos! [flickr.com]
Eureka Jim #1287569 Thu Nov 15 2018 07:31 PM
They exist, but as far as getting a deal.......
Eureka Jim #1287621 Fri Nov 16 2018 02:23 AM
Workshop Owner
The fact that they keep changing the batteries doesn't make it any easier. I'm sure that deals will be tough or impossible to find, but I will still be watching the ads just the same.
J Lucas
1941 Chevy 1/2-Ton
Eureka Jim #1287625 Fri Nov 16 2018 02:34 AM
Got a Kobalt from Lowes about 4-5 years ago and it is still holding a charge. Swivel head, magnet and you snap the end out and plug it straight into the outlet. Its my go to light but I'll never find another that will last that long!
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
52 Chevy Panel [photos.app.goo.gl]
Pictures in my Photobucket [s140.photobucket.com]
https://photos.websearch.com/share/...Nko1cUJCNFFMTVFEUnNRbjFhNTFPc1J4YWV4cmRB
Eureka Jim #1287692 Fri Nov 16 2018 03:51 PM
Caught one of these on sale last year. So far it's been a really good deal. Nice and bright with a couple different light level settings and it bends. Rechargable also.Light
Moderated by  48bigtrucks, MNSmith
