The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (mo2cyl, agedhorse, 1 invisible), 253 guests, and 3 robots.
Forums47
Topics117,839
Posts942,971
Members43,058
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Original AD hub caps on Modern Rims
#1273575 Tue Jul 24 2018 12:54 AM
So Old Blue, my 3600 Stovebolt, came complete with four pretty badly worn tires on the
original split rims and all four original hub caps. Pretty common with most of these original
medium duty Stovebolts
Since I’m a 95% purist, I spent a couple days breaking down those darn split rims
took them to the sand blaster, painted them with some good PPG enamel and bought
four new bias ply’s, tubes and flaps and let the tire dealer mount and balance them for me.
The were used to the split rims because they did a lot of farm and truck business.
Well…..after that first year of tooth jarring startups because of the bias ply’s, I started my
search for some new rubber. New rubber meant the split rims had to go, so….I found some
’80 GM 16.5” rims and mounted up some new Cooper radial’s. What a world of difference
in the ride. Problem now was I couldn’t use my original hubcaps with these modern
GM rims.
Easy solution, I got clips from one of the vendors and along with some round stock
standoff’s I turned in the lathe and some 10-32 screws, I mounted the clips. They worked
great for almost 10 years, never lost a hub cap.
But…..I still felt the ride could be a little better and tires for the 16.5” rims were by now
getting pretty hard to find and were quite limited, besides, if I had a blowout it would be
a real pain in the ars finding a new 16.5” tire.
A search of the junk yards turned up four nice ‘96 Ford F-250 16” rims, which after blasting
and painting with Valspar (never do that again, took forever to cure), I went all in and put a
good set of Michelin radials on the old gal. Now she finally was riding nearly as nice as my
new Silverado. A new problem though…those original hub caps again. This time it twern’t
gonna be as easy. The land between the lug holes was tapered 14° on these Ford rims, so
I couldn’t just use a simple stand off like on the Chevy rims.
A couple of evenings at the drawing board and I came up with a 14° wedged standoff.
Got one mounted up today and I’ll finish them off tomorrow when my special screws get
here.
So here’s the original ¾ ton hub caps mounted on late model tubeless rims.
Scroll thru a few pix of the wedges if you’re interested in using the idea for your
ride:
http://www.pbase.com/dennygraham/image/167852800/large
http://www.pbase.com/dennygraham/image/167852801/large
http://www.pbase.com/dennygraham/image/167852802/large
Denny Graham
Sandwich, IL
Re: Original AD hub caps on Modern Rims
Denny Graham #1273576 Tue Jul 24 2018 01:21 AM
I like yours much better than mine. Although they have been trouble free for years having a mechanical connection is to my liking. Mine are rare earth magnets epoxied to the wheel covers (hub caps) and iron, not steel discs on the front hub caps and rear axle centers. Thought I might need alignment pins but this turned not needed. Getting the spacing right was a pain and each cap is position specific. One has to pry HARD to get them off. Yours are beautiful.
Evan
Denny Graham #1273598 Tue Jul 24 2018 03:44 AM
You're only a 95% purist now, Denny? When did that change? You used to be 100%! grin
You must be slowing down in your old age!
Rich
'47 Loadmaster
Life is like a roll of toilet paper--the closer you get to the end, the faster it goes!
Denny Graham #1273618 Tue Jul 24 2018 12:32 PM
thumbs_up
Denny Graham #1273636 Tue Jul 24 2018 02:40 PM
Thank you Mr Graham.
I am slowing working toward exactly what you did. I was trying to figure out how to get around that taper. Your pictures help greatly.
Denny Graham #1273656 Tue Jul 24 2018 05:16 PM
Nice solution.
Another option is make new spring steel clips with the correct shape for the unique application.
Start with annealed spring sheet stock and have them heat treated if you can't handle that part in house.
1952 Chevrolet 3800 pickup
---All pictures---
Denny Graham #1273657 Tue Jul 24 2018 05:27 PM
If anyone uses aftermarket wheels (Wheelsmith, Wheel Vintiques, etc.), Wheelsmith will modify your caps to fit any style of wheels they sell. I used Wheel Vintiques Artillery wheels, which I knew my repop GMC caps wouldn't fit. Wheelsmith modified my repop GMC caps and they fit very snug, I'm very happy with them.
Just another option. Cool solution, Denny.
My 46 GMC on Photobucket
Denny Graham #1273663 Tue Jul 24 2018 06:57 PM
Nice job Denny. thumbs_up
J Lucas
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
1959 Chevy Apache 31 Fleetside
1959 Chevy Apache 32 Fleetside
1959 Chevy Viking 40
My Flicker Photos!
Denny Graham #1273673 Tue Jul 24 2018 09:05 PM
ace skiver
Real nice, as usual, Denny
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Denny Graham #1273691 Tue Jul 24 2018 11:38 PM
General Purpose
Denny, what is that piece I see between the wedge and the wheel? Wood? Rubber? Gasket? Optical conclusion?
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
Page 1 of 2 1 2
Moderated by  Justhorsenround
