The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
A lovely month ...
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 registered members (jayhawkdoug, Hotrod Lincoln, Brad Allen, 47PUJim, floaterboy, 1 invisible), 191 guests, and 3 spiders.
Forums47
Topics113,252
Posts897,975
Members41,570
Most Online940
Apr 5th, 2017
Image Posting Policy
1942 1 1/2 ton gvwr #1272255
Thu Jul 12 2018 05:12 PM
crc  Offline OP
new zealand
hi im new here and trying to find out the GVWR of a 42 1 1/2 ton with 160" wheelbase ive recently bought. only body tag I can find is on rh side of firewall cowling under the hood. its a factory rh drive truck, in new Zealand so no doubt it woulve come from Canada originaly. number on tag is xhms-34748. thanks for any help
Re: 1942 1 1/2 ton gvwr [Re: crc] #1272275
Thu Jul 12 2018 09:40 PM
3B  Offline
B. C. Canada
Hy crc, welcome, according to my Canadian parts books there were no 1 1/2 ton trucks produced 1941 through 1945 inclusive, straight from one tons to two tons. In those years they did not list G.V.W. only Capacity, in your trucks case capacity was listed as two tons. If you come up to 1951 when G.V.W. started to be listed, a truck very similar to yours had a G.V.W. of 14,500 lbs., hope that helps.
Re: 1942 1 1/2 ton gvwr [Re: crc] #1272293
Fri Jul 13 2018 01:02 AM
crc  Offline OP
new zealand
hi 3B, thanks. maybe its not a Canadian truck then? or maybe the info I got on the tag is incorrect? but sorry I cant remember where on the internet I found that info, but from memory the xh was 42 year and ms was160" wheelbase, which it is
. thanks
Re: 1942 1 1/2 ton gvwr [Re: crc] #1272300
Fri Jul 13 2018 03:11 AM
tclederman  Offline
Boltergeist
Jarvisburg, NC
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 50 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: 1942 1 1/2 ton gvwr [Re: crc] #1272429
Sat Jul 14 2018 03:33 AM
GreggE  Offline
California
I could never find the GVW on my 1942 1.5 ton either...sorry couldnt help you
Re: 1942 1 1/2 ton gvwr [Re: crc] #1272437
Sat Jul 14 2018 05:03 AM
3B  Offline
B. C. Canada
Hy crc, I found an American 1941 truck data book, the G.V.W.s range from 11,500 lbs. to 14,000 lbs., depending on springs and tires used, hope that helps.
Re: 1942 1 1/2 ton gvwr [Re: crc] #1273336
Sun Jul 22 2018 04:04 AM
Aus42blackout  Offline
Rockhampton, Queensland, Austr...
Hi CRC I have a 1 1/2 ton chev R/H drive that was brought to Australia durin ww11 as part of the lend lease program and was sold after the war finnished.
It didnt have any GVM numbers either, but the people who brought the truck put there name on a plate behind driver door and the GVM weight was 11,000 pounds 5 to 6 TON
I have just finnished restoring my truck but left the body all orignal as it is good shape
Cheers Justin
Moderated by  69Cuda, Grigg
Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
