The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
A lovely month ...
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
21 registered members (BigHog, 78buckshot, capnduane, 52vff, Apache1, 49nut, 2 invisible), 248 guests, and 3 spiders.
Forums47
Topics113,309
Posts898,462
Members41,589
Most Online940
Apr 5th, 2017
Image Posting Policy
3 speed clutch/flywheel options #1268990
Wed Jun 13 2018 04:56 PM
rew2resto  Offline OP
NC
1964 c-10. Removed the six and installing a 1994 350. I'd like to retain the original 3 speed column shift for now. I know its 168 teeth and came with a 10 inch clutch. Is there room to upsize (ex. bell housing clearance) and if so, any preferences on a clutch/flywheel combo that will match up to the V-8? Thanks so much!
Re: 3 speed clutch/flywheel options [Re: rew2resto] #1269058
Thu Jun 14 2018 03:03 PM
rfs56trk  Offline
Seal Beach, CA
V-8 trucks of that era would have had an 11" clutch and used the same bellhousing as the 6 cyl. Since you will need a different flywheel for the later engine as it has a different size bolt pattern on the mounting flange, purchase one that uses the 11" clutch. Get a clutch kit for the year of the truck with a V-8.
Fred
Moderated by  SWEET
Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
