The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
A lovely month ...
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 registered members (SavannahDog, Bill Marlow, joe apple, mo2cyl), 186 guests, and 4 spiders.
Forums47
Topics113,319
Posts898,671
Members41,594
Most Online940
Apr 5th, 2017
Image Posting Policy
250 swap #1268709
Mon Jun 11 2018 02:35 AM
koolkar  Offline OP
a little north of indy
howdy gang. it's been forever since I've been here but i'm yet again knee deep in a project and need some advice. I have a 51 3600 series that's the best one I've seen in years body wise.it has a 235 from a 55 in it that's in it with oil pressure issues. I've decided if that engine is coming uot, it ain't going back in even after I've spent a fair amount of money on it. i'm thinking a 250 with a 350 turbo hydro trans.. I remember(barely) from my youth there's a difference in the mounts but I can't remember what they are. I think the 250 is fatter on the bottom that the v-8 and the mounts are different. there's all sorts of places advertising v-8 mounts but I haven't seen a kit for the 6..i suppose I could go with the v-6 but I don't want to mess with the steering if I don't have to. (but I have considered an s-10 column to give me more belly room. any thoughts, knowledge in the 250/auto swap?
Re: 250 swap [Re: koolkar] #1268733
Mon Jun 11 2018 12:21 PM
Justhorsenround  Offline
Grease Monkey
Central, Oklahoma
Can't help with your question but it is good to see your signature again. Welcome back. chug
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: 250 swap [Re: koolkar] #1268738
Mon Jun 11 2018 12:37 PM
koolkar  Offline OP
thanks. looks like this is the over the hill cop forum, don't it?
Re: 250 swap [Re: koolkar] #1268739
Mon Jun 11 2018 12:51 PM
V
Volfandt  Offline
Knox County, TN
I just pulled a 250 out of a 49 GMC 100 (1/2 ton). It needed more work than I wanted to put in it.
The 228 that came in the GMC was longer than the Chevy 216/235/261 engines and based on what I observed with the 250, it is longer than the 228. The radiator on the GMC is already mounted more forward than the Chevy. There would have just barely been enough room for a mechanical fan but it sat too low so an electric fan is required. You may have to relocate the radiator alittle more forward, if so thats doable.
You'll need to cut the toe board and bend or cut the center panel for tranny clearance.
The 250's lower belt pulley barely cleared the GMC's front crossmember, I'm talking approx 1/4" - 5/8". Too tight to be able to get an alt belt on the inner groove without lifting the engine a hair or 2. So make sure you get a 3 groove lower pulley.
The 250 was bolted to a TH350 trans
Heres some pics:
right side mount
left side mount
balance barely clears the front cross member
right side view in engine bay
left side view in engine bay
This pic shows how the toeboard was cut and gives a pretty good view of the lower clamshell motor mounts:
Pic
Theres a bit of work to installing anything other than an AD era engine in an AD but a 250 would be alot less work than a SBC.
Good luck
Re: 250 swap [Re: Volfandt] #1268826
Tue Jun 12 2018 01:49 AM
koolkar  Offline OP
excellent pictures. thanks and good luck with your project.
Re: 250 swap [Re: koolkar] #1268868
Tue Jun 12 2018 01:00 PM
SavannahDog  Online
Georgia's Fresh Water Coast
This Company http://www.heidts.com/ makes motor mounts. I've been cautioned about using them because the piece that attaches to the frame bolts into the Web instead of the vertical piece. Easy enough to make another saddle piece and bolt it thru the vertical with bushings between the legs so you don't damage the mount while bolting it in place.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Moderated by  KCMongo
Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
