Is the engine a Chevy or GMC? Chevy's are about 3" shorter than GMC's so if the fan is way short of the radiator, Chevy, if about .75" short of the radiator-GMC. GMC's SN, r side, stamped on pad by starter, start with displacement, I. e. 228xxxxx, etc.
Ed
