Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
8 members (Patharr, hokiecarpenter, DES57, Hotrod Lincoln, Leo, 1 invisible), 270 guests, and 3 robots.
The Zone
Forums65
Topics123,442
Posts999,498
Members47,277
Most Online1,229
Jan 21st, 2020
Page 4 of 4 1 2 3 4
2-Ton #1425076 Fri Sep 24 2021 04:04 PM
If you don't have the fancy tool rests on your bench grinder, tack weld two 1/2" nuts together (flat to flat ) and you have a drill bit sharping guide. Put the bit into the v and and you can see any flaws in your bit and the angle is about right.
51 GMC 100 with 59 chevy 261 under the hood.
3 on the floor with 3.42 gear.
2-Ton #1453065 Fri May 27 2022 11:05 PM
I have worked for Lockheed Martin for some 50 yrs. and have drilled a few holes myself. We use a product called Boelube to keep our drilling from dulling of corse you bolters would cry if you knew what we did with most of our dulled out drills
. Basically Boelube comes in liquid form a paste etc. etc. We generally use push tube White and the 12oz. Blue. I believe you can buy it on Amazon
. Back in the early early days when I worked on the SR-71 we used Bees wax believe or not. It had already been mentioned but the harder the metal the more pressure and less RPM.
Page 4 of 4 1 2 3 4
Moderated by  MNSmith
