The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (baldeagle, Bill Marlow, carbking, DennisM, DES57, 1 invisible), 115 guests, and 3 robots.
Forums50
Topics120,516
Posts966,004
Members43,690
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Drill Bit Sharpening
#1266311 Fri May 18 2018 11:36 AM
2-Ton Offline OP
John at the homecoming asked me to do a seminar on how to sharpen drill bits.
With the cooking and all the other activities going on, we did not get a chance to do that.
But I have come across a how-to video that will show you how, on a belt sander.
You can also sharpen them on a bench grinder the same way.
https://www.youtube.com/watch?v=WnKavtC9NPk&feature=youtu.be
Hope this helps!
Don
"The Flag Pole"
In the Stovebolt Gallery [stovebolt.com]
More pix on Photobucket [s893.photobucket.com]
'46 2-Ton grain truck
'48 3/4-ton grain truck
'50 2-ton flatbed
'54 Pontiac Straight Eight
'70 American LaFrance pumper fire truck.
Re: Drill Bits
2-Ton #1266315 Fri May 18 2018 01:23 PM
Here's another drill sharpening video with more technical info and humor.
https://www.youtube.com/watch?v=r8oORR6jyh8
1951 GMC 250 in the Project Journals [stovebolt.com]
1948 Chevrolet 6400 [stovebolt.com] - Detroit Diesel 4-53T - Roadranger 10 speed overdrive - 4 wheel disc brakes
1952 Chevrolet 3800 pickup [stovebolt.com]
---All pictures [picasaweb.google.com]---
Re: Drill Bits
2-Ton #1266317 Fri May 18 2018 02:12 PM
2-Ton Offline OP
Good video Grigg III.
I really liked the humor and how he explained how a drill works.
Of course there are some more tricks for different types of material.
Speeds, feeds and lube are also a big factors.
But for most of us, it gives a better understanding, of how a drill works.
Wonder if this should be moved to the tool threads?
Don
"The Flag Pole"
'50 2-ton flatbed
Re: Drill Bits
2-Ton #1266322 Fri May 18 2018 03:28 PM
V
VEW Offline
Thanks guys. I learned something today.
Victor
41 3/4 Ton Pick Up (in process)
55 Grumman Kurbside (Doughboy) 235/3 on tree w/ OD
57 3100
58 C4400 Viking (Thor)
59 C4500 Short Bus (Magic Bus)
59 G3800 1 Ton Dually (Chief)
Re: Drill Bits
2-Ton #1266344 Fri May 18 2018 09:17 PM
Unrepentant VW Lover
Thanks Don! This is good info -- Good idea about moving it to the tools forum.
"There is a life about to start
When tomorrow comes..."
'49 Chevrolet 3804
Re: Drill Bits
2-Ton #1272548 Sun Jul 15 2018 06:26 AM
I have a friend who is an expert at sharpening with a belt sander. My dad did a decent job with a grinder. My hands shake too much, so I use a Drill Doctor. Used properly it does an excellent job.
Fred
52 3600
69 C-10
Re: Drill Bits
2-Ton #1272772 Tue Jul 17 2018 12:48 AM
I agree Fred. I use my drill doctor all the time. sure beats fighting a dull bit!
1949 Chevy 4400 216
Re: Drill Bits
2-Ton #1280073 Thu Sep 13 2018 04:20 AM
Boltergeist
Once the bit is sharpened, it stays that way a lot longer if it's lubed well. I like to use non-salted lard, mixed with a little Diesel fuel or Kerosene as a drilling lube. On those slow, heavy cuts, it smells a lot like bacon frying! Most people run drills too fast, too dry, and don't put enough down pressure on the bit. At the right RPM and down pressure, a sharp bit will roll a continuous tight spiral of cuttings out of the hole. If you let the bit "skate" without making chips, it will overheat and dull itself in a hurry.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Drill Bits
2-Ton #1280088 Thu Sep 13 2018 12:56 PM
It's amazing how many of those beautiful drilling and tapping cans of oil I have around the shop. I say beautiful because they go un-touched by most of the guys. My can look pretty well used, though.
Re: Drill Bits
2-Ton #1281021 Fri Sep 21 2018 05:37 AM
When i worked at Naval Weapons Station, Concord, the machinist gave me a Plews Oiler with Trans fluid and Diesel that he used for cutting oil.
Still have that, and still use it.
Page 1 of 2 1 2
Moderated by  48bigtrucks, MNSmith
