The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
20 registered members (ESum, Drew54, Bill Trotter, 5 Window 9434, 3 invisible), 386 guests, and 3 spiders.
Forums48
Topics117,294
Posts937,758
Members42,883
Most Online1,229
Jan 21st, 2020
Image Posting Policy
LED parking lights ‘46 Chevy #1262904 Wed Apr 18 2018 01:45 AM
46Sparky Offline OP
I am wanting to change the lighting to LED for the parking lights and also use the lights as part of the turn signals. Can someone that that traveled this path share their experiences?
46Sparky
Re: LED parking lights ‘46 Chevy [Re: 46Sparky] #1262933 Wed Apr 18 2018 04:29 AM
GWWirth Offline
I made my parking lights also turn signals. I did not use leds but nothing very magical about leds. The first thing to know is you need a different type of flasher as leds don,t draw enough current to heat the bi-metalic strip in a standard flasher. You then need to know the voltage 6 or 12. Leds are sensitive to voltage. Led arrays typically have a voltage limiting device and may have current regulation as well. You will probably have to mount an L bracket under the lens to hold the led array you choose. Depending on your turn signal set up and if you still want parking lights you might need two circuits. I made a new terminal strip for the fender a 4 pole.
Re: LED parking lights ‘46 Chevy [Re: 46Sparky] #1262942 Wed Apr 18 2018 11:40 AM
tclederman Online
Boltergeist
The largest selection of LED lighting for vehicles is probably ar Superbrightleds.
https://www.superbrightleds.com/search/led-vehicle-replacement-bulbs/6v/
These are later bulbs (for bulb codes), but do any of your bulbs match any of these bulbs?
Signal flashers for LEDs are available (6v LED flashers are rarer - maybe someone will post helpful information of a successful first-hand experience?)
Here is one example: https://www.amazon.com/Flasher-Negative-Vehicles-Memotronics-ELF33-6/dp/B06XSLDP53
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: LED parking lights ‘46 Chevy [Re: 46Sparky] #1262997 Wed Apr 18 2018 08:55 PM
46Sparky Offline OP
One of the reasons I am considering the LED option is I’ve seen comments elsewhere the milky white glass used in the parking light bezel assembly reduces the lights brightness. Is that a correct understanding?
I did look into the bulb options in the link Tim suggested. That looks like a viable parts source too. I am uncertain about the bulb size that was used for the 6 volt socket parking light originally. The socket is much smaller diameter than the tail lights. Also, the truck has been now been changed to a 12volt system.
Thanks for the info and any additional comments, guys.
Re: LED parking lights ‘46 Chevy [Re: 46Sparky] #1263037 Thu Apr 19 2018 04:02 AM
GWWirth Offline
Not sure how you are wired now. The oem light switch turns on the parking lights at the position before the headlights and off in the head light position. If you're wired this way the best option is a two contact socket if your looking for an led bulb. This is what I did but other possibilities exist.
Re: LED parking lights ‘46 Chevy [Re: 46Sparky] #1263046 Thu Apr 19 2018 12:33 PM
V
VEW Offline
Thanks for the info in this thread. Hope to get to this point this season!
Victor
41 3/4 Ton Pick Up (in process)
55 Grumman Kurbside (Doughboy) 235/3 on tree w/ OD
57 3100
58 C4400 Viking (Thor)
59 C4500 Short Bus (Magic Bus)
59 G3800 1 Ton Dually (Chief)
Re: LED parking lights ‘46 Chevy [Re: GWWirth] #1263050 Thu Apr 19 2018 02:06 PM
46Sparky Offline OP
The wiring for the parking lights isn’t completed yet and the headlight/parking light assembly is on the bench. Wiring to the switch is installed and mounted in the dash. Access to most everything related to the lights and turn signals addition is readily available.
I am thinking as a preferred option, of substituting use of the parking lights as originally used and use that hardware in as much as possible for turn signals instead. My preference would be to keep this as simple as feasible and avoid cutting etc. Ideally, the fix would a simple plug and play, much like the rear taillights I used.
I found the parking light bulb size for the original 6V system was. #55, 2 amp bulb.
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.7.3
