Chevy parts for sale. These are parts left over from the restoration of my 1936 Chevy pickup in the early 1970s. This is the cream of the crop because when I completed the restoration I took most of the left over parts to a swap meet and unloaded them. This stuff has been in dry storage for over 40 years. All prices are negotiable and I’m glad to provide more detailed information and photos. This stuff all predates cheesy repops from China.
4 ea. NOS front spring eye threaded bushings. $5 ea.SOLD
4 ea. NOS front spring eye bronze lined steel bushings. $5 ea. SOLD
1 ea. NOS appearing Trico vacuum wiper motor with speed control, # 404-G on the part. $45 SOLD
3 ea. used Trico vacuum windshield wiper pull/push knobs. $5 ea.
1 ea. NOS GM ring gear and pinion 1935-36 car and commercial and 1937-39 commercial, 4.11 ratio, GM PN 602476. $60 SOLD
1 ea. NOS differential pinion gear nut. $5
1 set of 12 NOS rocker arm bronze bushings. $15 for set of 12. SOLD
4 ea. 1932-36 NOS flywheel nuts GM PN 837004. $10 for set of 4.
1 ea. NORS clamp on “peep” mirror. $10.
3 ea. NOS packages of 4 water pump shaft packing rings. $5 per package of 4.
1 ea. used AC gas filter casting and glass bowl. I have found modern filter elements that fit these. Filter casting and bowl $5.
1 ea. rechromed grille shell center bar bow tie ornament. $20. SOLD
1 ea. used near perfect original bumper face bar elongate bolt $10. SOLD
2 ea. used pickup hood side bow tie emblems. $10. ea. SOLD
1 ea. set of 6 NOS Fitzgerald 71249 push rod cover seals, replaces GM 837264 $6 for set of 6
1 ea. 1934-36 Chevy NOS GM rocker arm shaft support PN 837251. $5.
1 ea. 1930s era AC 100 MPH speedometer, used, 4” bezel diameter, curved glass, number and needle paint excellent condition, actually works ! but should probably be serviced after 40+ years storage $50. SOLD
1 ea. NOS 1936-39 generator commutator cover band. $5 SOLD
1 ea. used 1934-40 horn button metal cup $3.
Misc. NOS windshield wiper blade pairs. $5 per blade.
2 ea. 1936-50 brake drums, standard size, USA made original parts. Listed as fitting some models front and rear, some models rear only, some models front only. $25 ea.
Ray
