The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis
Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
30 registered members (amtrakjoe, BC59, 55 SHAKER, 68ironhead, arustycars639, 5 invisible), 475 guests, and 3 spiders.
Forums47
Topics109,601
Posts861,768
Members40,466
Most Online940
Apr 5th, 2017
Image Posting Policy
41-46 Windshield Regulator #1254881
Tue Feb 13 2018 06:44 PM
V
VEW  Offline OP
VA
It is in fairly good shape. The stainless steel strip is good, as well as both ends. The splines on the handle are good and so are the threads that hold the handle on. Both the worm gear and main gear rotate freely. The problem is that one end on the die cast housing has been wobbled out a bit, so the gears don’t always make contact.
$175 plus shipping
Victor
41 3/4 Ton Pick Up (in process)
55 Grumman Kurbside (Doughboy)
57 3100
58 C4400 Viking (Thor)
59 C4500 Short Bus (Magic Bus)
59 G3800 1 Ton Dually (Chief)
Re: 41-46 Windshield Regulator [Re: VEW] #1254944
Wed Feb 14 2018 05:31 AM
GWWirth  Offline
WA, Near Portland, OR
The way I fixed the oval hole was to drill it out and press in a brass bushing. I also epoxyed it for added securement.
Re: 41-46 Windshield Regulator [Re: VEW] #1254960
Wed Feb 14 2018 01:11 PM
V
VEW  Offline OP
VA
I was going to use the tech tip from Kip to repair it, and then I happened to find another one that didn't need any work. Your suggestion/fix sounds like it would work just fine. Thanks.
Victor
57 3100
Moderated by  John Milliman, Tiny
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
