The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
A lovely month ...
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
19 registered members (D B Cooper, DennisM, Bill Marlow, EchoBravoSierra, 51sub, Apache1), 219 guests, and 3 spiders.
Forums47
Topics113,320
Posts898,692
Members41,594
Most Online940
Apr 5th, 2017
Image Posting Policy
What ever happened to KeyStock?? #1247333
Mon Dec 18 2017 02:22 PM
Denny Graham  Offline OP
Sandwich, IL
So my key stock is pretty much used up and I'm down to just a few pieces in
one of those little plastic drawers on the work bench.
So I thought I'd order a couple of sticks (12") of 1/8" thru 1/2" of
square cad/zinc plated stock. I used to get it from my local
hardware store.
Well, the big box stores, i.e., Menards, Home Depot, Tractor Store
Blain''s Farm and Fleet, Ace Hardware. don't stock it. Oh I can find
little 1" strips for a couple bucks each, but that's not what I'm lookin'
for.
Now my old Fall back to store, McMaster only lists over and under
sized key stock +/- .003" and it appears Grainger is the same.
What's up????????
dg
Re: What ever happened to KeyStock?? [Re: Denny Graham] #1247335
Mon Dec 18 2017 03:17 PM
Justhorsenround  Offline
Grease Monkey
Central, Oklahoma
Denny, have you checked Fastenal?
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: What ever happened to KeyStock?? [Re: Denny Graham] #1247336
Mon Dec 18 2017 03:21 PM
2-Ton  Offline
Mokane ,Mo.
Keystock was a quick and easy way to do machine setups when you needed parallels.
Tolerance on them were +/- .0005 in those days.
My suggestion is if you order some stock in?
Mic each one, every 1", both sides and use a sharpie to label each one.
To me, +/- .003, is just not acceptable.
Don
"The Flag Pole"
More pix on Photobucket
'46 2-Ton grain truck
'48 3/4-ton grain truck
'50 2-ton flatbed
'54 Pontiac Straight Eight
'70 American LaFrance pumper fire truck.
Re: What ever happened to KeyStock?? [Re: Denny Graham] #1247363
Mon Dec 18 2017 06:00 PM
Sandwich, IL
yep, same as the rest of them, oversize and undersize.
Nor is it to me either Don. Just can't figure what the deal
is. key Stock used to be held to size and close tolerance.
DG
Re: What ever happened to KeyStock?? [Re: Denny Graham] #1247370
Mon Dec 18 2017 08:43 PM
513600  Offline
California
cheap and China is what happened.
so you take the Mexican file and fit it
or size it on your surface grinder.
try working with some Chinese 6061 aluminum
Re: What ever happened to KeyStock?? [Re: Denny Graham] #1250214
Tue Jan 09 2018 07:39 PM
Dusty53  Offline
North East Missouri, USA
Denny,
We used to buy all of our shims and keystock through a distributor from "Precision Brand". This was back in the late 70's. I looked them up and here's a link to their site.
https://precisionbrand.com/products/14-square-keystock-zinc-plated-12-length-pack-of-6/
Ronnie
1954 Chevy 3604 - A work in progress...
" You can't keep dancing with the Devil and wonder why you're still in hell"
Re: What ever happened to KeyStock?? [Re: Denny Graham] #1250267
Wed Jan 10 2018 01:26 AM
Achipmunk  Offline
Boiling Springs, S. C. 29316
I checked out the site and checked for those that distribute their stuff. For my search 7 showed up and of the seven, 5 were listed at Fastenal and most of them from 3 to less than 25 miles from my house. Should have no problem finding them?!
Thanks for the link, Dusty. Good to know as I do have occasion to need some.
Pictures in my Photobucket
52 Chevy Panel
Re: What ever happened to KeyStock?? [Re: Denny Graham] #1254830
Tue Feb 13 2018 01:28 PM
David in MA  Offline
Plympton, MA
Unless I read Precision's page wrong, their keystock up to 5/8 was -.003 - + 003/ .004. They may offer specific sizes in between, but I didn't pick up on that. Actually, I need the odd + and - sizes often for custom & antique engs.. Have to mic them each time. Thanks for marking/ label tip. Duh on my part. David
Re: What ever happened to KeyStock?? [Re: Denny Graham] #1254945
Wed Feb 14 2018 05:43 AM
Hotrod Lincoln  Online
Boltergeist
Dellrose, TN
Not suitable for key stock (too brittle) but when I need a precision parallel I use large size high speed steel cutting tool blanks like 3/4" or 1" square stuff. The base plate of one of my boring bars has a slightly rough surface, so I put a couple of parallel bars between it and the top of an engine block on occasion. It helps to get a perfectly square alignment with the bore centerline.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: What ever happened to KeyStock?? [Re: Denny Graham] #1255040
Thu Feb 15 2018 02:46 AM
J Lucas  Offline
South Omaha, Nebraska
MSC has 12" lengths of key stock. Lot's of different sizes, plated, plain steel, stainless etc. Oversize, under size etc.
MSC key stock web page
I never used key stock for parallels but I have used tool bits (high speed, cobalt etc).
J Lucas
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
1959 Chevy Apache 31 Fleetside
1959 Chevy Apache 32 Fleetside
1959 Chevy Viking 40
My Flicker Photos!
Moderated by  48bigtrucks, MNSmith
Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
