The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (reidy, five-oh, mick53, 5WINDOWJOHN, Fox, 1 invisible), 239 guests, and 3 robots.
Forums50
Topics121,426
Posts973,547
Members43,932
Most Online1,229
Jan 21st, 2020
Image Posting Policy
216 ByPass Filter Drain
#1251996 Mon Jan 22 2018 02:53 AM
I have read that the outlet of the bypass filter on the 216 empties into the crankcase. Well on my 1951 216, this is not the case. The fitting where the filter outlet attached to actually leads to the low pressure side of the oil distributor valve.
1951 1 Ton Completed
Re: 216 ByPass Filter Drain
truckernix #1252001 Mon Jan 22 2018 03:32 AM
Boltergeist
In that case, the only time much filtering is going on is at idle, or other times when the oil distributor is at least partially closed. Once the pressures are close to equal on both sides of the distribution valve, little if any flow will get through the filter. I wonder if that's another way to assure the rods and mains get enough oil flow to stay lubed? Full pressure engines do drain the filter back to the oil pan through a port to the pan rail and a notch in the pan gasket.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Moderated by  Woogeroo
