The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Some light reading
ENTERTAINING ADVENTURES
In the Stovebolt Reading Room
A little light reading
OR
Epic stories of old tin hunting!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 registered members (Andyman, sack, Jimmie D, SimS, 53 green 1- ton, reidy), 288 guests, and 3 spiders.
Forums48
Topics117,365
Posts938,468
Members42,915
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Engine/Transmission/Axle Combo #1251676 Fri Jan 19 2018 11:47 PM
floaterboy Offline OP
This is my first post! I'm building a '56 3100. My plan is to run a 235 CI engine backed by a TH 350 that will turn the 3.73 rear end. I have all the parts and would like to use them and save $$$. Any experience or opinions?
Len
Re: Engine/Transmission/Axle Combo [Re: floaterboy] #1251706 Sat Jan 20 2018 03:42 AM
Joe H Offline
It sounds like a good combination once you figure out how to hook the automatic trans to the 235. Gearing would be about right with a 28" or taller tire.
Re: Engine/Transmission/Axle Combo [Re: floaterboy] #1251731 Sat Jan 20 2018 02:06 PM
EdPruss Offline
Buffalo in WA makes an adapter plate to bolt modern bellhousing to B, O, P, Chevy, GMC blocks.
Ed
Re: Engine/Transmission/Axle Combo [Re: floaterboy] #1251734 Sat Jan 20 2018 02:33 PM
panel fan Offline
If you don't already have one , check with the wreckers in your area, 235's and 261's came with automatic and have adapters for powerglides which I understand have the same bolt pattern as the th 350
good planning is no substitute for dumb luck
Re: Engine/Transmission/Axle Combo [Re: floaterboy] #1251754 Sat Jan 20 2018 05:37 PM
bartamos Offline
Truck Whisperer
My "experience and Opinion:"
Put in a V8, no adapters necessary. Why do you want a 6 cyl with a th350 and 3.73? Makes no sense. Gas mileage better...no, easier to do....no. Stay with original........no. There is nothing like the sound of a V8. Better resale also. Better acceleration.....looks better. Sell the 6 and buy a V8.
Where did the 3.73 come from?
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
Re: Engine/Transmission/Axle Combo [Re: floaterboy] #1251761 Sat Jan 20 2018 06:18 PM
Achipmunk Offline
...I think those adapter plates are about $450 bucks. That is enough to see what kind of "later/other" stuff is available. Makes even more sense looking at the "long haul". Just something to ponder about when you are sitting in that lazy boy thinking about how cols it is outside.
Pictures in my Photobucket
52 Chevy Panel
Re: Engine/Transmission/Axle Combo [Re: bartamos] #1251806 Sat Jan 20 2018 11:31 PM
The 3.73's are in a rear end I have laying around.
Re: Engine/Transmission/Axle Combo [Re: 52Carl] #1251962 Sun Jan 21 2018 11:20 PM
What did I miss here?
(NA) Re: Engine/Transmission/Axle Combo [Re: floaterboy] #1251972 Mon Jan 22 2018 12:13 AM
SWEET Offline
ODSS Lawman
Gentlemen
Let’s stay on topic. This thread is asking how to do something. Not asking for opinions. A better approach would have been to show this combo may be cost preventative and leave it at that.
SWEET
Sergeant At Arms
Old Dominion Stovebolt Society
BUNS?!?!?! Where we're going, we don't need no buns.....
1950 GMC 450 (25% owner)
1951 Chevy 1/2-Ton
The GreenMachine
(NA) Re: Engine/Transmission/Axle Combo [Re: floaterboy] #1252044 Mon Jan 22 2018 05:04 PM
Mike B Offline
Like Joe H said, the 235 will not bolt up to the TH350...different bolt patterns.
Mike B smile
Page 1 of 2 1 2
Moderated by  SWEET
Powered by UBB.threads™ PHP Forum Software 7.7.3
