The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis
Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
26 registered members (canuck49, Burgy, amtrakjoe, BC59, 55 SHAKER, 4 invisible), 473 guests, and 3 spiders.
Forums47
Topics109,601
Posts861,768
Members40,466
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 2 1 2
Re: Output yoke for closed drive sm420 [Re: yellosub54] #1250790
Sat Jan 13 2018 04:28 PM
sstock  Offline
Gig Harbor, WA
I see you want the entire assembly. Use the ujoint and outer yoke from the 3sp and just look for the inner yoke that attaches to the trans of the sm420, it should be the same for either the 1/2 ton or 3/4 ton. The donor trans that I am using for my swap came from a 3/4 ton and the input yoke will work with my stuff.
pm me youe email and I will send you some pics
1953 Chevrolet 3100
Re: Output yoke for closed drive sm420 [Re: yellosub54] #1250803
Sat Jan 13 2018 06:30 PM
Elderly Iron  Offline
Southern Oregon
No yoke. I bought a bed full of stuff. Has the 420 and the first drive shaft, but no yoke. I never sorted through that pile since I got it. I found a complete sway bar! WOO HOO!!!
Re: Output yoke for closed drive sm420 [Re: yellosub54] #1250823
Sat Jan 13 2018 08:52 PM
jorb  Offline
Wis
The U-Joint assembly is everything in THIS illustration.
The main parts of the U-Joint assembly are the front yoke, trunnion and rear yoke.
You can buy a U-Joint assembly or some of the items separately.
There are different yokes for 3 & 4 speed trannys.
Master Parts Catalog Yokes Group # 5.555
48-54, 1/2 ton, 4 speed tran. Front Yoke, part # 3686323
40-54, 1/2 ton, 4 speed tran. Rear Yoke, part # 3681934
48-54, 1/2 ton, 3 speed tran. Front Yoke , part # 591644
40-54, 1/2 ton, 3 speed tran. Rear Yoke, part # 3665768
Master Parts Catalog U-Joint Assembly Group # 5.548
48-54 1/2 ton, 3 speed tran. U-Joint assembly, # 591642 - Chevs of the 40's Scroll down.
48-54 1/2 ton, 4 speed tran. U-Joint assembly, # 3689266
40-54, 1/2 ton, 3 & 4 speed tran. Repair kit part, # 609944 Chevs of the 40's
Includes - 1 trunnion, 4 bearings, 2 snap rings, 4 hex bolts, 2 lock plates.
Call http://nwtparts.com/ Ask for John.
They should have everything you need.
You can also try Partsvoice For NOS parts. Just punch in the parts numbers and see what comes up.
Picture of a 4 speed 1/2 ton torque tube U-Joint Assembly.
1941-54 u joint .jpg (107 downloads)
1954 Chevrolet 3105 Deluxe Panel Truck
w/Factory HYDRA-MATIC
Re: Output yoke for closed drive sm420 [Re: yellosub54] #1250835
Sat Jan 13 2018 10:24 PM
original  Offline
Rocky Mountains
Hi,
Just sent you an email with photos of 5 of them. All Original...
Not from the reproduction places.
Thanks marzach for the heads up for this persons needs.
Re: Output yoke for closed drive sm420 [Re: yellosub54] #1250920
Sun Jan 14 2018 04:33 PM
sstock  Offline
Gig Harbor, WA
Thanks for posting this info jorb.
1953 Chevrolet 3100
Re: Output yoke for closed drive sm420 [Re: yellosub54] #1250993
Mon Jan 15 2018 01:55 AM
Y
yellosub54  Offline OP
sonora, ca
FOUND ONE! Thanks everybody.
"I always win." Working mainly alone I do not let my trucks win a war. Maybe a battle here and there but never the war.
Robert
55.1 GMC 450 COE
51ish GMC Suburban
Re: Output yoke for closed drive sm420 [Re: yellosub54] #1255782
Wed Feb 21 2018 03:07 AM
Chinito Quan  Offline
Guatemala City, Guatemala
Hi guys. After many years hiatus, got back on the horse. Can you please point me where did you found the front yoke assembly. Greatly appreciated. Also if anyone knows where to find part NO. 591679 (rear cover of SM420 transmission for the ball joint)
Re: Output yoke for closed drive sm420 [Re: yellosub54] #1255783
Wed Feb 21 2018 03:11 AM
Y
sonora, ca
There is a front yoke on ebay right now. Just make it's correct for what you need.
Robert
55.1 GMC 450 COE
51ish GMC Suburban
Re: Output yoke for closed drive sm420 [Re: yellosub54] #1255789
Wed Feb 21 2018 03:28 AM
Thanks. Do you have the link. If i put the part No. Louis Vuiton bags appear and Scuba yokes.
Re: Output yoke for closed drive sm420 [Re: yellosub54] #1255836
Wed Feb 21 2018 02:51 PM
Y
sonora, ca
Not sure if this is what you're after.
Yoke
Robert
55.1 GMC 450 COE
51ish GMC Suburban
Page 2 of 2 1 2
Moderated by  John Milliman, Tiny
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
