The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Come one; Come all
14th Annual Stovebolt Reunion
In Kansas City, MO
September 8 and 9
Check for details and sign on!!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
34 registered members (3B, 1951Chevy1Ton, 49 3100, 46forme, 53 green 1- ton, 6 invisible), 206 guests, and 3 spiders.
Forums47
Topics111,895
Posts881,199
Members40,932
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 2 1 2
Re: help-ideas donar truck for 37 [Re: coolwhip] #1250806
Sat Jan 13 2018 07:00 PM
goneagain  Offline
north Idaho
Personally i wouldn't do the S10 swap. you lose a lot of the bed for wheel wells. a rear end from 72 nova bolted right into mine. I agree with Joe H and his list.
1937 Chevy 1/2 ton panel
1938 Chevy 1/2 ton pick up
Re: help-ideas donar truck for 37 [Re: coolwhip] #1251143
Tue Jan 16 2018 03:38 AM
coolwhip  Offline OP
springhill fl.
I'm staying with orginal frame, restore body . update drive train , brakes ,steering add a/c and help out susp. have a truck. want a truck.just one that will haul butt when need be. is there a"newer " truck out there or vechicle to get me what I want/need take off newer bolt/weld on old? thankyou everybody for your help and help to come.
Re: help-ideas donar truck for 37 [Re: coolwhip] #1251279
Wed Jan 17 2018 01:44 AM
Joe H  Offline
Lee's Summit Mo. 64086
If you are going with factory style steering box, up grade to a 41-46. You will need to do a little custom work to the steering wheel shaft if you want the '37 horn and steering wheel. The box will bolt in as is, the shaft will need the '41 -'46 wheel on it. Internally, the gear box uses ball bearings, and a slow gear ratio, so they steer much easier at slower speed. The '37 box is gear to gear.
You can also adapt the '46 leaf springs up front for a softer ride.
Page 2 of 2 1 2
Moderated by  KCMongo
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
