The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis
Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
20 registered members (D B Cooper, 47fivewindow, LKetchum, 1953 panel, 2 invisible), 390 guests, and 6 spiders.
Forums47
Topics110,736
Posts871,757
Members40,644
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
Wanted drive and driven speedometer gear for sm420 #1250623
Fri Jan 12 2018 06:06 PM
sstock  Online OP
Gig Harbor, WA
would like part number 3689223 which has a drive gear of 4 teeth and a driven gear of 12 teeth.
But will consider anything you have for a sm420 because I can use an adapter on the outside of the trans.
Thanks in advance,
Steve
1953 Chevrolet 3100
Re: Wanted drive and driven speedometer gear for sm420 [Re: sstock] #1250668
Fri Jan 12 2018 10:25 PM
Y
yellosub54  Offline
sonora, ca
My GMC master parts book doesn't list that number. Is this for the 3100? Do the 3/4T and 1/2T use the same gears?
"I always win." Working mainly alone I do not let my trucks win a war. Maybe a battle here and there but never the war.
Robert
55.1 GMC 450 COE
51ish GMC Suburban
Re: Wanted drive and driven speedometer gear for sm420 [Re: sstock] #1250687
Sat Jan 13 2018 12:55 AM
sstock  Online OP
Gig Harbor, WA
They do but the number of teeth changes based on rear end ratio and tire combination. This number is for a 1/2 ton with stock tires. At this point I would settle with any combo just so I can bolt the yoke on. Then I could use an exterior speedometer ratio adaptor.
1953 Chevrolet 3100
Re: Wanted drive and driven speedometer gear for sm420 [Re: sstock] #1250690
Sat Jan 13 2018 01:09 AM
Y
yellosub54  Offline
sonora, ca
Ok. I have a set but can't get rid of them until I know if I can find a complete yoke assembly for a 1/2T. I'm waiting on multiple people to check their hoards. I'll let you know if mine come available.
Robert
55.1 GMC 450 COE
51ish GMC Suburban
Re: Wanted drive and driven speedometer gear for sm420 [Re: sstock] #1250729
Sat Jan 13 2018 04:21 AM
sstock  Online OP
Gig Harbor, WA
ok thanks, but Im a little confused on why yours will not work. The SM420 that I'm using came out of a 54 3/4 ton and the yoke and ball mount will fit my 1/2 ton. Are you sure yours was not out of a 1 ton?
Send me your email and I'll launch you off some pics tomorrow.
Steve
1953 Chevrolet 3100
Re: Wanted drive and driven speedometer gear for sm420 [Re: sstock] #1250870
Sun Jan 14 2018 03:17 AM
sstock  Online OP
Gig Harbor, WA
ttt
1953 Chevrolet 3100
Re: Wanted drive and driven speedometer gear for sm420 [Re: sstock] #1251480
Thu Jan 18 2018 04:54 AM
sstock  Online OP
Gig Harbor, WA
anyone??
1953 Chevrolet 3100
Re: Wanted drive and driven speedometer gear for sm420 [Re: sstock] #1251509
Thu Jan 18 2018 04:14 PM
Y
yellosub54  Offline
sonora, ca
I don't have a set. I found the u-joint/yoke setup I needed and had to swap my gears over.
Robert
55.1 GMC 450 COE
51ish GMC Suburban
Re: Wanted drive and driven speedometer gear for sm420 [Re: sstock] #1251511
Thu Jan 18 2018 04:21 PM
sstock  Online OP
Gig Harbor, WA
Thanks for checking, that is pretty much what everyone does. I just finished up my 3sp rebuild, I replaced bearings/sychros and one gear, it had a chipped tooth. The trans feels brand new now. I still want to run a sm420, I opened up a sm420 and now can see why I want to run one. These transmissions are substantial, I dont think you could hurt one in a 3100, talk about built.
1953 Chevrolet 3100
Re: Wanted drive and driven speedometer gear for sm420 [Re: sstock] #1251550
Thu Jan 18 2018 11:42 PM
Mike B  Offline
Hughesville, MD
The same SM-420's were used in the 2-1/2 ton trucks from the factory...they are bullet proof in a 1/2 ton truck!
Have you contacted Novak to see if they have the parts you need?
Mike B smile
Page 1 of 2 1 2
Moderated by  John Milliman, Tiny
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
