The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis
Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
16 registered members (D B Cooper, 47fivewindow, LKetchum, 1953 panel, 2 invisible), 385 guests, and 6 spiders.
Forums47
Topics110,736
Posts871,757
Members40,644
Most Online940
Apr 5th, 2017
Image Posting Policy
1965 C10 - fuse wiggles breaks contact #1250176
Tue Jan 09 2018 04:18 PM
Woogeroo  Offline OP
Socket Breaker
Tool Box
1965 Chevrolet C10 lwb/long bed step side
my C10 still has the original style fuse panel with the glass bulb fuses.
The fuse on the heater blower circuit, sometimes it wiggles just enough after I hit a bump or something and it breaks contact, the heater blower turns off.
I'm sure I'm not the only one to have this issue or something similar.
I am curious if there are any safe fixes some of you have come up with?
Thanks.
-Woog
Re: 1965 C10 - fuse wiggles breaks contact [Re: Woogeroo] #1250183
Tue Jan 09 2018 05:12 PM
beltfed  Offline
Knoxville, TN
Depending on where I am and what I have available, I’ve uses aluminum foil, solder wick, or built the metal ends with with solder.
Re: 1965 C10 - fuse wiggles breaks contact [Re: Woogeroo] #1250201
Tue Jan 09 2018 06:20 PM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
As a last resort, use a universal fuse holder and solder the wires to the existing fuse block clips. Sometimes the clips are just too far gone to salvage without replacing the whole fuse block.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: 1965 C10 - fuse wiggles breaks contact [Re: Woogeroo] #1250204
Tue Jan 09 2018 06:28 PM
Justhorsenround  Offline
Grease Monkey
Central, Oklahoma
Old time shade tree fix. Trim two pieces of aluminum foil about 1/8 inch wide and 1/2 inch long. Wrap a piece around each end of the fuse and put the fuse back in. Should tighten the fuse up enough to keep it from vibrating loose.🛠
'62 Chevy C-10 Stepside Shortbed
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: 1965 C10 - fuse wiggles breaks contact [Re: Woogeroo] #1250208
Tue Jan 09 2018 06:36 PM
EdPruss  Offline
Longmont, CO
Frequently the reason fuses cause the rivets to get loose is the fuse gets hot, from overload or being too small-amp wise- mike sure to check fuse temp, might have to use larger size if always hot.
Ed
'52 GMC 630 w/ 603 gasser, ex fire truck.
Re: 1965 C10 - fuse wiggles breaks contact [Re: Woogeroo] #1250216
Tue Jan 09 2018 07:43 PM
bartamos  Offline
State48 Ranch
The short fix is to wire around the fuse holder and add an inline fuse as Jerry said.
The long fix is to take fuse panel out and repair or replace.
You can take the fuse out and abandon that circuit. Add a hot wire from somewhere else; thru an inline fuse to heater fan switch. No need to mess with, or solder to, the fuse panel.
1960 GMC K10 (The Oreo SpeedWagon)
Re: 1965 C10 - fuse wiggles breaks contact [Re: Woogeroo] #1250222
Tue Jan 09 2018 08:37 PM
Boltergeist
Dellrose, TN
A friend substituted a .22 rimfire shell casing for a tail light fuse that kept blowing while towing his duck boat on a hunting trip. It turned out the cause of the problem was an intermittent short in the trailer wiring. It would have probably been a better idea if he hadn't used a live round. When the short happened the next time, it got everybody's attention when the brass got red hot and lit off the powder. Nothing like the equivalent of a good-sized firecracker going off under the dash!
Re: 1965 C10 - fuse wiggles breaks contact [Re: Woogeroo] #1250226
Tue Jan 09 2018 09:01 PM
Grease Monkey
Central, Oklahoma
Back in my younger stupider days I would cut the head off a 1/4 in Bolt and put it in place of a fuse. Didn’t have the money for a box of fuses. Fortunately I never burnt anything up. 🛠
Re: 1965 C10 - fuse wiggles breaks contact [Re: Woogeroo] #1250367
Wed Jan 10 2018 08:23 PM
Rusty Rod  Offline
Moderator - The Electrical Bay and Rocky Mountain Bolters
Loveland, Colorado
wrigleys chewing gum wrappers work great too...
Another quality post.
Real Trucks Rattle
Re: 1965 C10 - fuse wiggles breaks contact [Re: Woogeroo] #1250833
Sat Jan 13 2018 10:05 PM
Woogeroo  Offline OP
Socket Breaker
Tool Box
Thank you for the replies everyone.
Good stuff and entertaining stories... haha.
I took the fuse out and checked the clips for wiggle, they seem solid. I don't know if the fuse itself was cracked before or broke while I removed it, as it was REALLY in there on the right hand side of the panel, but the glass was cracked, so I replaced it with a new fuse.
Before I did that tho', I bent the right side clip down a smidge, then snapped the new fuse into place.
So far no issues with the heater going off... but will keep an eye on it.
Thanks!
-W
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
