The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy New Year
2020
A New Year
A New Decade
A New Vision
Ring in the new with some quality time with your old truck! A great time to tackle a winter project. If you do not have access to your truck, start your parts list for spring!
The days are officially getting longer now, you know!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 registered members (55 SHAKER, bhap, Barnfind49, Hambone, bluesman, sweepleader), 417 guests, and 3 spiders.
Forums48
Topics117,109
Posts935,688
Members42,781
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
235 adjustments #1249717 Sat Jan 06 2018 04:14 AM
I
Ian Ring Offline OP
235 backfiring through carb and jerking and missing, especially under load, what do I need to do? Is it timing?
Stovebolter -- the Next Generation
(I'm 20)
1941 Chevy 1/2-ton pickup
"Lucy"
More pix on Photobucket
1967 Ford Mustang - "Sally"
Re: 235 adjustments [Re: Ian Ring] #1249719 Sat Jan 06 2018 04:21 AM
Achipmunk Offline
This very thing happened recently to a bolter. I believe his turned out to be in the distributor....a good place to start. The thread is not very old so maybe a few topics down you will find it.
Pictures in my Photobucket
52 Chevy Panel
Re: 235 adjustments [Re: Ian Ring] #1249733 Sat Jan 06 2018 11:31 AM
tomctomc Offline
Timing can do it, but so can a lean condition. Lean (insufficient fuel) can also cause a miss. A lean mixture burns slower which means combustion can still be underway in a cylinder when the exhaust valve opens. This ignites the charge in the intake manifold intended for the next cylinder in the firing order - and you get a backfire through the carb. So check your distributor/timing as suggested, but also look for something that is causing a lean mixture (clogged jet, low float level, etc)
Re: 235 adjustments [Re: tomctomc] #1249817 Sat Jan 06 2018 11:46 PM
Dragsix Offline
I am a start with the basics kind of guy. Pull the plugs and make sure not fouled or cracked. Just for giggles, do a compression test. See if anything is all of the sudden way out of wack. Next, I would bring the motor up to top top dead center or where ever the spec is for no. 1 to fire on your motor. Trace the no. 1wire to the distributor cap tower and put a chalk mark under the no. 1 wire tower. Remove the cap. The rotor should be pointing at the chalk mark or pretty darn close. Check the cap, make sure it’s not all gummed up or filthy or just plain worn out. Check the point gap. How old is the coil? Vacuum advance is next, make up a little adapter and rubber hose arrangement so you can sort out whether the diaphragm is bad. If it is, you have both a bad vacuum advance and a vacuum leak. You might also pull the valve cover and just make sure no bent push rods, broken push rod cups, of flat cam lobes (no lift on one or more valves.
Mike
Re: 235 adjustments [Re: Ian Ring] #1249823 Sun Jan 07 2018 12:45 AM
Hotrod Lincoln Offline
Boltergeist
Do a valve adjustment, then a compression test.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: 235 adjustments [Re: Ian Ring] #1249832 Sun Jan 07 2018 01:25 AM
JW51 Offline
Ian, I know the engine was relatively “new” to your truck. Did it run fine for a while? Or has it acted like this since installed?
Re: 235 adjustments [Re: JW51] #1249868 Sun Jan 07 2018 05:44 AM
I
Ian Ring Offline OP
It ran fine for a while and then past few days it got cruddy, I played with timing but that didnt a lot, replaced coil so that's fine. I thought my next thing is to check for a vacuum leak and I dunno what else
(I'm 20)
"Lucy"
Re: 235 adjustments [Re: Ian Ring] #1249928 Sun Jan 07 2018 05:53 PM
RdsLessTaken Offline
Have you checked your fuel tank, line, fuel pump, fuel filter and carburetor for sediment? My truck behaved similarly, I even had to tow it home once, as it would not pull even a modest hill for missing, bucking and backfiring. Even a tiny amount of rust, or sediment in the system can cause symptoms you describe.
Re: 235 adjustments [Re: RdsLessTaken] #1250021 Mon Jan 08 2018 09:55 AM
tomctomc Offline
this is what i think happened. it explains the sudden onset of symptoms.
Re: 235 adjustments [Re: Ian Ring] #1250099 Tue Jan 09 2018 12:21 AM
I
Ian Ring Offline OP
When I changed the engine I didn't put a fuel filter, back cause my fuel pump has a screen in it, I'll put a filter in a see it that helps
(I'm 20)
"Lucy"
Page 1 of 2 1 2
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
