The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (BC59, Cletus1950, homer52, Hotrod Lincoln, Fox, 1 invisible), 166 guests, and 5 robots.
Forums60
Topics123,936
Posts1,000,136
Members44,787
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 3 of 4 1 2 3 4
Re: 292 motor mounts
mick53 #1248954 Sun Dec 31 2017 09:30 PM
I have a dimensioned copy of the original metal adapter, how do I attach a copy?
Ted
1950 Styleline 2-door with 261
1951 Truck 3100 with 235
Thirdtimer #1248955 Sun Dec 31 2017 09:37 PM
The copy is terrible, send me an email address and I will mail you a full size copy.
Ted
Ted
mick53 #1248962 Sun Dec 31 2017 10:54 PM
my email: info@kitarakorjaamo.com, thanks very much, and good new year!
rane
mick53 #1249413 Thu Jan 04 2018 01:43 AM
Thirdtimer, I would also Iike a copy of the pattern. Can e-mail to g_i_joe@cox.net, thank you
mick53 #1267866 Sat Jun 02 2018 05:34 AM
I think the front motor mount is a great idea in that it uses the stock position but are there any concerns with its strength and the amount of stress placed on it with such a high torque engine?
1950 Chevrolet 1/2-Ton 3100
mick53 #1267878 Sat Jun 02 2018 12:56 PM
Sucking fans are more efficient than pusher fans; since 292's and their brothers are longer than 235's, etc., in Chevy's, ( GMC do not have this problem) it would be a good idea to move the radiator forward slightly in the core support to be able to use an original fan, give more room for accessories. For additional heat capacity, use a fan shroud, with a rolled edge around the fan, fan blades should be centered in shroud. Holes in shroud should have flaps of some heavy material to open when road air pushes them open-see-VW Rabbit, etc.
Neoprene mount material is readily available in 1" thick by 4" wide by length as snowplow blade material; Florida residents will have to look elsewhere.
Ed.
mick53 #1267904 Sat Jun 02 2018 06:58 PM
I see you used the Flathead Ford mount cushions which in my opinion are as good as any ever made. I use then for all motor mounts and many transmission mounts. On my straight eight Buick the engine really rocked and rolled with the factory mounts so I welded some extensions to the timing cover mount plate and used the flathead cushions. No more rocking.
[img]https://s22.postimg.cc/noddniei5/Straight_8_a-c_mount_001.jpg[/img]
[img]https://s22.postimg.cc/7dd9ra219/Straight_8_a-c_mount_002.jpg[/img]
Evan
mick53 #1273446 Mon Jul 23 2018 02:25 AM
ASU Offline
I am looking to put a 292 in my 48 3600. I like the idea of the horseshoe front mount, but I am lost on the rear mounts. My 292 has a bell housing with the angled mounts. My current 235 has the flat mounts. I have found pictures of how to notch and weld the 48 cross member to match up to the angled bell housing. I cannot find motor mounts to put between the bell housing and cross member. Any suggestions?
Thanks Jon
Thirdtimer #1404302 Thu Apr 01 2021 10:39 PM
Thirdtimer: I'm working on getting a 292 set up to install in my 1951 3800. I found this post from several years ago that shows pics and dimensions for a front motor mount. Looks to me like it would be a whole lot simpler and cleaner than the side mounts I have seen in other posts. If you still have this information, I would be obliged if you could send it to me so I can fab one up for my own use. Email is packhousemike@gmail.com Thanks. Mike Jury, North Carolina
mick53 #1404310 Thu Apr 01 2021 11:13 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Thirdtimer hasn’t been around for over 3 years. I doubt you will get a response.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
Page 3 of 4 1 2 3 4
Moderated by  Woogeroo
