The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (66rollback, DougH6100, Drew54, ccanepa50, DennisM, 1 invisible), 218 guests, and 3 robots.
Forums50
Topics120,897
Posts969,144
Members43,785
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Does 4speed have a cross member support?
#12486 Mon Sep 23 2002 07:01 PM
I want to put a 4 speed with granny in my 55.1. I have a 3 speed lite duty in it now. There is no cross member support for my 3 speed tranny. Was there a support for the heavier 4 speed? Is it a cross member or some other sort of bracket? Thanks - Scott
55 1st Chev.
Re: Does 4speed have a cross member support?
#12487 Mon Sep 23 2002 07:19 PM
scott you musta been reading my mind. I was about to post the exact same question. My 66 has the 3 speed/no support in it and I'm going to a significantly larger MY6/89MM 4 speed and wondered if I needed a crossmember.
I think I'm going to be on the safe side and buy one I saw at Golden State parts for 50 bucks. It can only help.
I don't think you can go wrong if you go ahead and get one for your 4 speed. Overkill at best.
-ftyler
#12488 Mon Sep 23 2002 08:00 PM
Yes, if it is more securely mounted, it will make the whole assembly stronger. cool
#12489 Mon Sep 23 2002 10:29 PM
ace skiver
There was no rear support in 54/55-st for the 1/2 ton truck transmission (unless you had a HydraMatic transmission). The motor mounts and the frame crossbrace for the motor mounts changed in 1954, supposedly making the rear mount for the 3-sp and 4-sp transmission unnecessary.
I have never had one on my 1/2-ton '54 pickup and it had a 4-sp on it from the factory (no holes in the steering column for the 3-sp shifter box).
Tim
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
#12490 Tue Sep 24 2002 12:58 AM
Not sure what you figure to accomplish by using a crossmember with a trans that has no mount for bolting it to.
#12491 Tue Sep 24 2002 07:12 AM
#12492 Tue Sep 24 2002 07:29 PM
Junior Member
I REPLACED THE 3 SPD TRANNY IN MY 53 W/ A SAGINAW
4 SPD OUT OF AN 82 PONTIAC FIREBIRD AND FABRICATED
A TRANNY X-MEMBER FOR IT BY USING A 1 1/2" SQUARE
TUBING AND BOLTED IT IN USING #8 NUTS AND BOLTS
JUST TO BE ON THE SAFE SIDE...ALOHA
#12493 Wed Sep 25 2002 07:03 PM
tclederman, or anyone else....What are the proper numbers for the 4 spd original tranny type? The junk yard needs to know. Also any installation tips would be helpful. - Thanks for all replies!
55 1st Chev.
#12494 Thu Sep 26 2002 01:58 AM
SM420
[img]http://www.jeeptech.com/convtrans/sm420/4202.jpg[/img] [img]http://www.jeeptech.com/convtrans/sm420/4205.jpg[/img]
The pictures came from these guys. http://www.jeeptech.com/convtrans/gm/gmsm420id.html
This page will tell you a little more about the trans.
http://www.novak-adapt.com/knowledge/sm420.htm
If you want to go to the later SM465 like I did, you have to change bellhousing.
You can see it is as Jack said about the mount.
'67 GMC 3/4 292 4spd
#12495 Thu Sep 26 2002 03:38 PM
Wow!!!That is more than I could have hoped for....
Thanks much Richard!
55 1st Chev.
Page 1 of 2 1 2
Moderated by  Woogeroo
