We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
Forums60
Topics127,506
Posts1,032,026
Members45,793
Most Online1,229 Jan 21st, 2020
 Screw at base of window channel - 47 AD
OP
Stovebolt Photo Moderator
Good Morning,
I am installing new glass in the doors of a 47 AD. The window edge trim around the perimeter of the glass attaches to the window regulator hardware with a "male/female" screw setup. I've been able to make and improvise just about all the hardware on the truck. This one stumps me, as it is so small and flush with the trim. Anything that would stick out proud would keep the window from traversing the channel. I'm almost thinking to put a slight weld between the 2 pieces. Or at least ask my buddy...........I can't weld.
Anyone come across this situation? I don't imagine there is a source for the screw setup. I was able to remove the old clutch head and female receiver.
Thanks, any suggestions would be appreciated.
Joe
 Re: Screw at base of window channel - 47 AD
Do a search for rivet nuts. Threaded rivets.
OP
Thanks - I will try that.
Sir Searchalot
Maybe something like one of THESE.
Watch out for careful drivers!!! I'm away on an ego trip. Will be back on Feb 30. I'm not an Auto Mechanic, but I play one on TV. I charge $0.02 for every opinion and I take Paypal. Plan B is always better than plan A, by definition. I recommend invoking MIL-T-FP41c when machining and fabricating I used to think beer was bad for me, so I gave up thinking. Sometimes no nonsense makes sense, in a sense. You can't teach a new dog old tricks. Honk if you're Amish
classicparts.com has those screws/sleeve nuts. Part # 70-811. $4.95 enough for both sides.
Sir Searchalot
Too bad I didn't find that source before I made my own on my hillbilly lathe. Cordless drill and bench grinder, that is. It only took me 3 times and most of a day to get it right.
Sir Searchalot
It's OK, good experience and UPS does not deliver to Butcher Holler anyway.
Joe, do you know someone who works in a body shop? I had a friend who does all sorts of restorations who had the tool to put them in and had a supply of the rivet with the kit. I'd think most shops would have one. (I needed the rivit nuts on my door panel) Worked like a charm.
It's OK, good experience and UPS does not deliver to Butcher Holler anyway. It ain't no fun climbing the telephone pole with my laptop to order stuff neither. I'm still proud, however not of being a coal miner's daughter...
