The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members ('37 barn find, artinva, Asahi1234, 7045george, NorthCoast3800, Achipmunk), 105 guests, and 3 robots.
Forums60
Topics124,693
Posts1,006,456
Members45,005
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Best Options for front axle swap in a 41' 1.5ton
#1247331 Mon Dec 18 2017 02:05 PM
Capt D Offline OP
I'm looking for alternatives on axels and wheel combinations. I currently have a 41 1.5 ton GMC with 20in wheels. I have read some of the threads regarding the P30 axle swaps. Is the P30 the only option or is there others? Any advice or information would be greatly appreciated. This may have been covered previously and I might have just overlooked it. Thanks for your time.
Re: Best Options for front axle swap in a 41' 1.5ton
Capt D #1247368 Mon Dec 18 2017 07:42 PM
Big Bolt Forum Moderator
Welcome to the site! I am not completely sure on different axle options but, if there is a truck wrecking yard in your area, it may be good to take a bunch of measurements on yours and then go to the wrecking yard and poke around. You may fine some other moving van or motorhome that has an axle that would work well in there.
Mike
1955 Chevy 6400 ex-flatbed (no bed now!)
In the Stovebolt Gallery [stovebolt.com]
Capt D #1247390 Tue Dec 19 2017 12:15 AM
Front axles are narrower, so adding P-30 spindles makes sense. Get a 2 ton axle to start with.
Ed
Capt D #1247463 Tue Dec 19 2017 01:15 PM
Capt D Offline OP
Thank you for the information. I will continue to research this and try to find the best alternative. If I choose to stay with the original axle, what options do I have to go away from the original wheels? Preferably a 19.5. Current wheels are the 20in, 5 lug wheels.
Capt D #1247508 Tue Dec 19 2017 06:28 PM
I've looked for and at different front axles for many years now. In my opinion the best fit (because truck is narrow) is the original axle, or one from same body style truck, larger or possibly smaller.
The sticky thread about axle and brake swap stuff is most all of what I know on the matter, and the short version is...
A 2 ton axle beam for your model truck will fit, (possibly even from 48-53?). With that axle beam you can adapt P-30 spindles, hubs, and brakes with very little effort.
See info and measurements in the sticky thread.
Wheels and tires have options too, and much info and discussion Here
Short version... 19.5" wheels may not fit over your rear drums, or they may, better check.
If they do fit they need a bushing to adapt the 5.25" center bore to your 4.75" hub (nominally).
19.5" wheels with 8R19.5 tires, as tall as fit the wheels, are still only 32-33", and may look small, it's up to you.
The original 20" wheels if in good shape can still be a good option.
22.5" wheels in this 10 lug on 7.25" bolt circle are old and hard to find, but do exist. 9R22.5" tire is about 38" tall.
Grigg
1951 GMC 250 in the Project Journals [stovebolt.com]
1948 Chevrolet 6400 [stovebolt.com] - Detroit Diesel 4-53T - Roadranger 10 speed overdrive - 4 wheel disc brakes
1952 Chevrolet 3800 pickup [stovebolt.com]
---All pictures [picasaweb.google.com]---
Moderated by  69Cuda, Grigg
