The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Thinking again ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (NJC, 78buckshot, rgie, DougH6100, Paul_WNC, 1 invisible), 62 guests, and 3 robots.
Forums60
Topics127,583
Posts1,032,706
Members45,812
Most Online1,229
Jan 21st, 2020
Image Posting Policy
'59 Saginaw 4 speed w/350 V8
#1246136 Fri Dec 08 2017 03:59 AM
Any issues with running a '59 Saginaw 4 speed transmission with a 350 V8 versus the original 283 V8? I know the Saginaw is strong and I believe should be able to handle the increased horsepower and torque. Thanks for input.
Re: '59 Saginaw 4 speed w/350 V8
JackAttack #1246144 Fri Dec 08 2017 05:57 AM
I have a 1970's (?) Saginaw 4-speed in my '56 3100 with a mild 350 and it work fine, but I don't abuse it either!
Mike B smile
Mike B #1253798 Mon Feb 05 2018 06:40 AM
Mike B smile
Mike, what difficulty or mods did you have to make to get the Saginaw in there. I've got a Saginaw out of a '69 chevelle that I'd like to put in my truck, which is a '55 series 2 3100.
Jim
1955 Chevy series 2
6 cylinder, 3 on the tree
Short bed, step side
JackAttack #1253842 Mon Feb 05 2018 05:52 PM
I didn't have to do any real modifications to put the 4-speed Saginaw (Camaro trans) in my 1956 3100. My 350 has a V8 truck bell housing so I'm hanging the Saginaw off the back just like the SM-420's were done. I installed a T&F Shifter that puts the shifter in the original 4-speed location with only a little trimming to increase the floor hole opening.
T & F Shifter
31799 Chestnut Lane
Lebanon, OR 97355
541-451-1929 Mark
I don't think he has a web site...
Mike B smile
Last edited by Mike B; Mon Feb 05 2018 06:08 PM. Reason: image fail and then I got it :)
JackAttack #1253855 Mon Feb 05 2018 07:14 PM
A few of my competitors on the dirt tracks ran Muncie 4 speeds behind beaned-up 350's with few, if any problems. Hammering on and off the throttle at 3-6K RPM several times a lap with the transmission in 2nd. gear had a habit of showing up weak spots pretty quickly. The aluminum case Muncie transmissions would handle 2nd. gear that way, but if somebody tried to use 3rd. with a lower geared rear end, the case would split wide open after a few laps. The Saginaw has a cast iron case, and appears to be much heavier and more durable than the Muncie. That's a misconception - - - -apparently the gears and synchronizers are a little weak.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
JackAttack #1308988 Tue Apr 30 2019 01:02 AM
I know this thread was originally started 16 months ago and the last post was 14 months ago. I only wanted to say that interior pic shows a clean setup. Nice work.
Professional Novice
JackAttack #1309176 Wed May 01 2019 01:09 PM
Can the original emergency brake be kept when using the Saginaw?
I just pulled my SM420 which had a dowel about the diameter of your thumb that the Emergency brake lever pivoted on. The Saginaw of course lacks this provision.
1950 GMC 250 Pickup
1965 Mustang Convertible
1972 K5 Blazer
1973 Buick Centurion 455 Convertible
JackAttack #1309346 Fri May 03 2019 02:55 AM
Thanks for the compliment Frank!
Buckkoo...what year and series truck are you asking about???
Mike B smile
Moderated by  SWEET
